1976 Maverick backfiring issues
Discussion in 'Technical' started by Lee12, Jul 24, 2024.
  1. Lee12
    Lee12 Member
    Carl Junction, MO
    76 Ford Maverick
    Got it running and took it around the block but it backfires alot. Only been able to get up to 40mph and doesn't have good acceleration. Anyone know what the issue might be?
  2. 71_GT
    71_GT Member
    Mississippi
    Out the carb? I had same issue but on a rebuilt engine. Was told to use a 351 firing order and that was the problem. Needed a 302 firing order.
  3. Krazy Comet
    Backfire out carb is most likely wrong firing order.
    Ronald Hopkins likes this.
  4. Powerband
    Powerband Member
    NY's \H/
    more info needed for armchair analysis - new problem or new to you vehicle? ...
    6 or 8 - firing order is simple to check as mentioned.
    Ignition timing , distributor cap etc condition is suspect.
    if been sitting - stuck valve or more serious internal problems
    pulling plugs and static compression test is likely next ...
    have fun
    Krazy Comet likes this.
  5. TeeEl
    TeeEl Senior Member
    Colorado
    If it's backfiring out the exhaust, a defective A.I.R. diverter valve can be the cause. A carb backfire is usually ignition timing related...
  6. Lee12
    Lee12 Member
    Carl Junction, MO
    76 Ford Maverick
    Where is this located at?
  7. Lee12
    Lee12 Member
    Carl Junction, MO
    76 Ford Maverick
    How do you check the firing order?
  8. Krazy Comet
    It should be on intake, though not always, with cam swap may not be correct anyway.
    Verify spark plug wires are in correct order.
    If so, 302 & std 5.0 order is 15426378. HO 5.0(1982 & later) & 351 13726548. Swap 5 with 3 & 4 with 7. If that fixes problem great, if it's worse, you have other problems.
    TeeEl and dyent like this.
