1978 ford pick up 9 inch rear end
Discussion in 'Technical' started by lynhrt210, Dec 30, 2010.
  1. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Ok found a 9 inch finally for cheap but it came off a pick up,how much work would it take to put in the maverick?
  2. Jamie Miles
    Alto, GA
    I've had a few
    Housing will need to be shortened and axles will need to be shortened, resplined and redrilled to the 5.25" pattern or new axles. Trucks also have the 31 spline axles vs. 28 in cars. Could probably have the axle tubes from your 8" welded on it and put a 28 spline diff. in.
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I've heard that some trucks had the 28 spline axles. Also heard you could swap the spider gears, 28's for the 31's. For sure would have to use the Maverick or other 8" ends,backing plates and drums, and axles. Like Jamie said, you should be able to use your 8" axle tubes in the 9" chunk....unless you have a 4 lug 8"....they have smaller ends and different axles.
  4. justin has a 74
    kentucky
    Yep it is pretty spendy to have all that work done .Most machine shops are at $40 an hour shop rate ..
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    This is correct. I have grabbed 2 different 3rd members out of trucks and both were 28 spline. Both trucks were six cylinder powered.
  6. baddad457
    Times three on this. Lots of trucks had 28 spline axles. 78 could be either 28 or 31.
  7. baddad457
    If you're going to spend money narrowing it, go with new 31 spline axles and use the truck's rear drum brakes, you'll just need to swap to drums with a 5x4.5 bolt pattern.
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    double check that housing,,, most likely has the big axle tubes and more of a oval pumkin housing, not the cicle round.
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The spline count depends more on year than anything, when it comes to trucks.
    Some years were mostly 28 spline, some years were primarily 31 spline.
    For 200-250, here, you can have your 8" tubes welded to a 9" housing pumpkin.
    This is the way Ford did it in for the K-codes.
    As long as the finished product is the same exact width as the donor 8" (and the 9" chunk is 28 spline), you can use your Maverick axles and brakes. It'll bolt right in because you pretty much have the same rear you took out, except the center is modded to accept the 9" chunk.
  10. baddad457
    Then there's the ones with the big 31 spline sized axles, that are necked down at the inner ends to 28.
  11. Jamie Miles
    Alto, GA
    I've had a few
    I guess I missed the part where I said trucks ONLY have 31 spline axles (in fact I own a '78 F150 with 28 spline). If it's out of a truck, you may as well just assume it's 31 until you can verify.
  12. ratio411
    ratio411 Member
    Pensacola
    I have seen truck years grouped into 2 catagories, but not being a truck guy, I don't know the years by heart. You'd have to look it up. But there are known years that you should assume 28 splines until you verify, then other known years that 31 splines should be assumed until you verify.
  13. ratio411
    ratio411 Member
    Pensacola
    There are 3 housing centers:
    round-car = strong, but weakest of the 3.
    oval- big car/truck = strong
    banjo (long oval) = heaviest and by far strongest.
    The banjo housing is supposed to be most common in big cars, especially Lincolns.
  14. baddad457
    Isn't there 4 counting the early 9" rears ? You know, the one's that look like the 8" from the backside ? (ala, 57-59 Ford)
