1985 F-150 V8 w/ MFI
Discussion in 'General Maverick/Comet' started by Mr Nick, Jun 22, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Well damn.
  2. Mr Nick
    Grapevine, Texas
    So get new heads is what you're saying, right? ;)
  3. Krazy Comet
    If it's in the budget... BUT the pistons won't have valve reliefs so other than Trick Flow, anything really good will have piston to valve clearance issues...
    If you could locate a stock HO 5.0 roller cam(Stang guys used to just about give them away), that will bump Hp by at least 35... The '86 HO 5.0 'Stang used the E6 heads(one year only) and HO cam, was rated 200Hp vs the '87-'92 225Hp that used E7 truck heads... Were other minor differences in EFI components from '86 to '87 that bumped Hp... Assuming headers and efficent exhaust system, the truck/'87-up HO heads are probably worth 20Hp over the E6...
    Another possibility would be run this Lunati flat tappet cam that's similar to the HO roller(yeah I'm ducking)...:hide: That would allow use of a stock '70s cast iron gear dist...
    http://www.summitracing.com/parts/lun-10350700lk/overview/
  4. Mr Nick
    Grapevine, Texas
    But the Pistons do have valve reliefs??
  5. Mr Nick
    Grapevine, Texas
    Couldn't I also just get some comp cams and call that good?
  6. Krazy Comet
    Nope they are flat top with a small dish, reliefs aren't needed with the E6 heads... With a small cam E7 can be used, at least a couple of the T-Bird guys tried them had no issues...
    Cam mfgr is mostly preference, all sell similar grinds...
  7. Mr Nick
    Grapevine, Texas
    I'm almost 100% that they're valve reliefs because they're 2 on each side of the cylinder
  8. Mr Nick
    Grapevine, Texas
    I'll post a pic when I get home
  9. Mr Nick
    Grapevine, Texas
    So I would need 2 of those lunatis right? Would those be enough to move on some rice burners?
  10. Krazy Comet
    Huh, two??
    OHV engines have only one cam... OHC engines have one per head, DOHC engines have two per head...
    A lot of the newer ricer stuff is pretty quick... As long as it isn't something with variable cam timing, turbo, supercharged or a shot of Nawssss, you should be able to keep up... Probably even pass once you get rollin'...
  11. Mr Nick
    Grapevine, Texas
    Alright so I'm looking to put out 300 hp, what do I need to do?
  12. Mr Nick
    Grapevine, Texas
    Stang net (mustang forum) says they have an 85 with XXX in the valley and it's a roller
  13. Krazy Comet
    AFAIK all XXX or YYY blocks are roller, doesn't mean they are built with same heads, cam etc...
    1985 was 1st year for roller cam, was used only in carbed, 5-speed Stangs, nothing else... By mid year most all blocks were roller cam capable but generally hold downs for cam spider were not machined...
  14. Mr Nick
    Grapevine, Texas
  15. Bryant
    the 92 f150 8.8 will be too wide, have a 5 on 5.5 lug pattern and not match up to the maverick suspension. it would need to narrowed and custom fit to the car and requrie new axles and different drums.
    yes it can be made to fit but is not a cost effective choice.
