1985 F-150 V8 w/ MFI
Discussion in 'General Maverick/Comet' started by Mr Nick, Jun 22, 2015.
  1. Krazy Comet
    If you are talking BBK 1515 shorties, they won't begin to fit into a Maverick engine bay(at least while bolted to engine)....
  2. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Alright. So which ones do fit? Because I need shorties for column shift
  3. Mr Nick
    Grapevine, Texas
    Also, where can I get the frame mounts?
  4. Mr Nick
    Grapevine, Texas
    And dont you bolt headers on after placement into the engine bay?
  5. Krazy Comet
    Yeah but they still won't fit as the pipes extend outward far enough to hit shock towers... I have the 1515 on my T-Bird and tried actual fit in the Comet, not happening...
    No Idea what headers can be used, need some that tubes curve downward and run below plugs...
  6. Mr Nick
    Grapevine, Texas
    so I can cut the shock towers (as alot of us have done) and call it a day?
  7. Krazy Comet
    I dunno, are quite a bit wider than headers that fit... I wasn't going to cut so quit at that point...
  8. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    My merc. mountaineer 5.0 got a roller cam from sumitt , $180.00. This was the cheapest rooler 5.0 i could find. Is this normal?
  9. Mr Nick
    Grapevine, Texas
    That's about what I paid for mine. It varies by lift but only slightly.
  10. Mr Nick
    Grapevine, Texas
    Are we positive I need a rear sump pan for the 302? Bc it looks like my power steering shaft is in the way
  11. Krazy Comet
    No -- You need a front sump pan... I reused all the parts(oil pan & pickup, timing cover, brackets, etc) from my orig 302...
  12. Mr Nick
    Grapevine, Texas
    Damnit.
    So which oil pickup screen did you use?
  13. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    The oil pan and pickup would be the same as used on all 1965 to 1973 small block mustang and all V8 mavericks!
    If the engine came from a car 1979 or newer the front cover needs to be changed because the newer engines have no place for the dipstick, All newer cars have the dipstick in the side of the block !
  14. Krazy Comet
    Several other models used the front sump pan as well, Falcons, Fairlane, Torino, Cyclone, Cougar etc, full size through '72(302 dropped for '73), as did '75-'80 Granada, Monarch & Versailles...
  15. Mr Nick
    Grapevine, Texas
    Why would this matter?
    Also, it's been a while since we've talked about oil pans, so excuse my ignorance :slap:
