1989 5.0 hp
Discussion in 'General Maverick/Comet' started by HOMERMAV, Jan 16, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    that sounds good bryant because my cam is only good to 6200rpm as far as nos i will have to keep that in mind maybe a 100 shot when im racing will keep things from burning up.
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    the heads are off a 89 mustang with bowl work and exh work multi-angle valve job 3 on the seats 2 on the valves that car ran 13.30s at 102mph weighing 3370lbs with 200000 miles on the short block:chirp:i had lots of fun with that car
    brad:)
  3. scooper77515
    Were you getting the wheels off the ground in a 13 second car? With e7s?
  4. 71gold
    306 ci....600/AFRs/RPM/6901s/AOD...230 Dynoed RWHP...
    est. 310 HP motor.. '73 Mav.
    ...:yup:...
  5. scooper77515
    You too, Frank?
    Can I get my wheels off the ground with my setup?
    308 ci, 750 double pump holley, gt40 heads, single plane, C4, 26" slicks, 3.80 spooled rear, and 265 dynoed rwhp?
  6. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    so my goal is very close 275 at rwhp but i think i will have to change my gears from 3.50 to the 411s i have. looks like a new intake is in order also.
    thanks everybody
    john
    frank what gears are you using in the rear end
  7. 71gold
    3:55 ...:Handshake
  8. Bryant
    you can cheat the chassie dyno by running higher gears. (numaricly lower). so puting 4.10s in will get you a lower number than 3.55s will.
  9. 71gold
    :hmmm:...how much lower...maybe some 2:79s then...:yup:
  10. Bryant
    the problem with 289s is that the mph on the dyno gets to high and the dyno shuts down. i know this because it happend to me. kinda sucked. the dyno shuts off and doesnt record the numbers. it was a 175mph if i rember correctly.
  11. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    thanks frank
    bryant what gears are you running
  12. Bryant
    right now i have 4.57s. my dyno number is at the flywheel. i had the motor dynoed befor i put it in. i have a thirdmember with 3.25s for when i want to cruise the streets and go freeway speeds with out spinning my motor to the moon.
