2.3 turbo maverick new track times
Discussion in 'Drag Racing' started by maverick88tc, Apr 25, 2009.
  1. timers
    timers Member
    richardson tx
    1974 maverick
    Are you talking about the 2.3 single over head cam motor that came in some of the courier trucks or have things change since 79 with my motor that i have?
    I do know that the all cast iron motors 2.3 are good motors.
    But the earlier aluminum castings had problems?
    If you are using the motor that i have in my truck all cast.
    And you can run times like that, Then i'll never blow up the motor in my truck
    so i can start cutting shock towers, fire wall for the 302.
    Cool car and even better the engineering
  2. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    yes it is the cast iron 2.3 made from like 73-99 or something like that , i have put a water methanol injection kit on my car now so i intend to turn the boost up some more, i am going to run a seperate tank for race gas with a seperate pump to supply fuel for the nos kit. so i will be spraying race gas pump gas water and methanol all at once.
  3. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Around here, we go by the philosophy "Run what ya brung and hope you brought enough".
  4. ATK
    ATK Member
    D/FW
    Both
    Well said...if you can't hang with the big dogs then you better stay on the porch
  5. maverick88tc
    maverick88tc Member
    athens tennessee
    i have built a water/meth kit that i got on it today but i have to wait for my new boost gauge to get in so i can tell what i am doing. i bought one that goes to 35 instead of 25 i love outgrowing a boost gauge.
    here are the parts i used to make the kit
    1.boost switch from coolingmist.com(15$)
    2.size 12 nozzle from the same (10$)
    3.stock ford in tank elec fuel pump (free)
    4.1/4 inch nylon line from lowes with correct fittings (6$)
    5.5 gallon degreaser jug from my work (free)
    6.a standard relay (free from work)
    so i have like 30 dollars in it and i will let you know how it does, my goal is 32-36 psi on pump gas
  6. Fat Tony
    Fat Tony Member
    Upstate,SC
    Why spend a few thousand when you can spend a few hundred... I have had it all, turbo cars, blower cars and nitrous cars... all three have their uses. The most fun I have ever had was in my 2.3T swapped 92 Mustang LX. My 2000 Mustang GT had a NOS Nozzle kit on it and ran 8.60's on motor (1/8th mile) and in the upper 7's (on drag radials, i say 7's as it depended on if the tires broke loose or not ;))with a 75 shot. My first car was a 75 Camaro with a bored and stroked small block with a 671 bolted to the top... that one saw in the 9's (1/4 mile) before the motor let go and sent me into the wall at 160mph. Either way, there are power adders for every budget... and (not picking on anyone in particular here) anybody who thinks that nitrous is cjheapting then also needs to include any power adder in that mix..
  7. Fat Tony
    Fat Tony Member
    Upstate,SC
    yes, same motor...but has forged pistons (for turbo apps)
  8. Jeff S
    Jeff S Member
    NoVA
    none
    Good post Tony
    How much does a bottle cost and how many times can you spray before you have to refill/replace it? Ive never messed with the stuff...lol
  9. Fat Tony
    Fat Tony Member
    Upstate,SC
    you can do a nitrous setup for as little as like $400... but the drawback is that the fun only lasts as long as that $20 worth of gas does ;)
    In any case, if you run the car enough on the gas, it doesn't take long to add up to the cost of a supercharger of turbo setup..
  10. Jamie Miles
    Alto, GA
    I've had a few
    We're talking about this engine. This engine was optional in the Courier in 1979. The aluminum engines were totally different.
  11. maverick88tc
    maverick88tc Member
    athens tennessee
    i wieghed the car last weekend and it is 2750 with very little fuel and me in it is that about normal ?
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    The only issue i ever had with buying and using nitrous is, if you buy a good kit with a few options and use it quite a bit you could get a supercharger or turbo setup and make as much or more power.
  13. courier11sec
    courier11sec Member
    Tucson, AZ
    88tc-
    That is awesome!
    Also what an unexpected sound coming from your car in the video! Very damned cool.
    Nice work.
  14. maverick88tc
    maverick88tc Member
    athens tennessee
    thank you i like it
  15. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Thats a pretty light car.:yup: Mine weighs 2,910 ibs. without me in it but I have a roll cage and a 9" rearend in it.
