2 questions and then some needed parts.
Discussion in 'Technical' started by ptpdub, Mar 22, 2015.
  1. ptpdub
    ptpdub Member
    canada Sk.
    I have a manual steering box and pitmin arm off a 72 maverick. Before I can ask my question I need some terminology and naming help. On the passenger side of the car is the unit the pitmin arm connects to. What is this called? Is this the idler arm?
    Now my question is does that piece need to be replaced if someone is swapping from power to manual steering? My car is a 75 with a 302. It had power steering but the manual pitmin arm threaded end is too short and can not have a nut on the end.
    Anyone know? The details are. 1972 steering components on a 1975 car.
  2. rthomas771
    Yes, its the idler arm. 70-74 and 75-77 use different center links and this cause for a different idler arm. They were 3 different idler arms...70-72. 73-74 and 75-77. The 75-77 pitman arm is also different than the 70-74 pitman
  3. ptpdub
    ptpdub Member
    canada Sk.
    This is great info, anyone have any leads on a 75-77 maverick manual steering parts?
  4. baddad457
    Just FYI: the Pitman arm connects to the center (or drag) link. which connects to the idler arm on the passenger side.
  5. ptpdub
    ptpdub Member
    canada Sk.
    thanks, I think I have the wrong year parts.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    If you get all the parts from the same year you should be able to transplant them onto your car.
