200 ci engine noise
Discussion in 'General Maverick/Comet' started by anthonyv90, Feb 2, 2013.
  1. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    start with the compression test first if one cylinder is far lower then the others better count on tearing the head off. if they are all low then go for the timing chain. but make sure of the cause of the problem first throwing parts at it can get expensive if you do not have the problem identified.
  2. rthomas771
    If it jumped valve timing...moving the ignition timing is not going to do anything to make it run better.
  3. doncomfort
    chillicothe oh
    You're right, my bad.
  4. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Anthony, I would check 2 things. A cracked distributor cap. Fuel filter also. If you don't get the correct amount of fuel to the piston, you starve the egine from creating power.Let me know if this helped you.
  5. mercgt73
    Keep in mind, if it jumped time, your compression numbers may be lower than expected. Just look for any that are significantly different (>20%) than the others.
