200 Inline 6 to 302 bellhousing
Discussion in 'Technical' started by Deerhog, Jun 29, 2017.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    I have a 1973 mercury comet gt that has a 200 straight six in it and I have an opportunity to get a 302 that used to be in a 77 pickup from a friend for next to nothing. I figured that it would take a different bell-housing to bolt that 302 to the 3-speed manual that the six cylinder is bolted to now (i could be wrong). I wanted to know if anyone knows of a bell-housing that would work and if you do let me know that would be great. Would it better to get another transmission altogether? Also what other problems might I run into doing this swap? Thanks.
  2. Krazy Comet
    At the least you'll need bellhousing, flywheel, clutch & pressure plate... Also clutch & throttle linkage, plus motor mounts, radiator etc etc... I dunno if small 6cyl & v8 trans used the same input shaft or bellhousing bolt pattern...
  3. 71gold
    I think the Z bar is also different.
  4. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Try typing in " 200 I6 to 302 Conversion" in the search function.
    :cheers:
    MD
  5. rthomas771
  6. Deerhog
    Deerhog Member
    Texas
    What is the 3-speed manual transmission called? That would help to find a bell-housing. Was the 3-speed in my car used with a 302 in other cars equipped with that engine?
  7. rthomas771
    3.03
  8. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    It would be better to get another transmission altogether.
    If the trans could be made to bolt up, lots of changes would be required. Then you would still have A very light duty 3 speed.
    It would probably be as easy and economical to upgrade to something with overdrive. As many times as it's been done, it's been figured out. Every problem has been solved.
  9. Deerhog
    Deerhog Member
    Texas
    Does anyone know of a used manual transmission that would fit into the comet behind a 302
  10. Deerhog
    Deerhog Member
    Texas
  11. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    A T5 seems like A perfect choice here.
    That bell is for A top loader. It won't fit the t5 without an adapter.
  12. Deerhog
    Deerhog Member
    Texas
    What transmissions were used in v8 comets?
  13. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    I believe that they were all 3 speeds. I don't know what they were named (top loader etc.). I bet some one else here knows.
  14. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    rthomas771 already told us. The link he posted gives the names.
  15. Deerhog
    Deerhog Member
    Texas
    It would be nice to find out because I don't want to spend the money to put a t5 in the car right now. If I could find an old manual transmission that I know will go in the car behind a 302, or possibly use the one I am using now, that would be great. If I can't find a bellhousing online are there any companies that make custom ones? I am sure that people have made more odd requests before.
