200 Inline 6 to 302 bellhousing
Discussion in 'Technical' started by Deerhog, Jun 29, 2017.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    Would any year model T-10 fit into the car?
  2. Deerhog
    Deerhog Member
    Texas
  3. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    I am pretty sure that one won't work.
    eBay item number:
    282504616013
    Something like this would.
  4. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
  5. Deerhog
    Deerhog Member
    Texas
    OK. How hard is it to do a swap like this? Like setting up clutch linkage or speedometer for example.
  6. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    The speedometer could be as easy as plugging the original cable into the t5. You might need to replace the gear on the cable. Those are about $10.
    I used the '85 mustang clutch pedal, cable and quadrant.
    Since you already have A clutch pedal (I didn't), it might be better/easier to use one of the hydraulic clutch setups.
  7. Krazy Comet
    Per Hollander's Interchange, all the column shift manual transmissions from '71-'76 are swappable... They assign a unit/stock number & it's same(1295).. No real doubt the floor shift would probably swap as well, likely something like linkage were different...
    Info is from a 1981 edition, by that time if they'd made a mistake it would have come to their attention...
  8. rthomas771
    I think the only difference between a 6 cyl 3.03 and V8 3.03 is the gear ratio. I think the 2.77 3-speed transmission was in the history books by the time the Maverick came along.
  9. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    Is that showing that it's the exact same transmission for the column shift manual, from the 170 up to the 302?
    And that the floor shift transmission is different from the column shifted one?
  10. 71gold
    then you don't want to have a company... make a custom bellhousing.
    rthomas771 likes this.
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Ounds like your best bet is to find a V8 bell housing, flywheel, clutch and linkage then install what you have now.
  12. rthomas771
    Only difference between a column shift and a floor shift transmission is the direction the shift linkage is facing...one transmission has the linkage facing up...the transmission has the linkage facing down,
  13. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    Are the numbers listed in the Hollander chart in post 22 for the shift mechanisms or the transmissions?
    I think I don't understand.
    I would expect A different gear ratio to warrant A different part number.
    Now I have more that I need to learn. I just can't believe That the trans for the 170 is interchangeable with the one for the 302.
  14. Krazy Comet
    It's the transmission, granada used same one in '75 & '76... In '77 went to 4-speed O/D... If those were not so difficult to find would be a good choice, hot rodders don't want them because they aren't as strong as std toploaders... Seen guys using them behind big blocks without issue...
    Third listing in this chart puts it to bed... The 170 did use a different ratio, but 200 through 302 use same input shaft/gear in most of the three speeds used in Full size(A), Fairlane(B), Mustang(F), Maverick(P), Bronco(U) & Falcon(X)..
    Ford Master Parts only lists through 1971, no reason to think later units would be any different...
  15. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    Well how about that. Thanks Tom.
    With the appropriate (v8) bell, clutch parts and z bar it looks like A bolt in. Good stuff to know. I get more smarter every time I come here.
