2002 dodge dakota not starting
Discussion in 'Non-Ford Engines' started by Countryboy0385, Feb 19, 2016.
  1. Countryboy0385
    Countryboy0385 Member
    Michigan
    2002 dodge dakota
    I just replaced the timing chain on my 2002 dodge dakota 4.7l and went to start it and it made a loud bang coming from the right side head. I thought it was the cam positioning sensor and replaced it and it did the same thing again. I checked all wires for propped installation on everything I took apart and still have the same issue. Can anyone give me pointers on what to do next?
  2. mav1970
    Did you replace the timing chain because the chain slipped or broke? If so you might have a bent valve from the time the engine was still revolving without the chain being connected until it stopped.
  3. Countryboy0385
    Michigan
    2002 dodge dakota
    I replaced the chain because the right side one was loose. When I took it apart the v8 on both cans was at 12 o'clock including the primary. The crankshaft was at 6 o'clock. I replaced the whole thing including all guides and tensioners.
  4. Countryboy0385
    Michigan
    2002 dodge dakota
    One more thing it does the loud bang once and that's it. Only after the camshaft position sensor is changed. I read many forums and some are saying that the sensor has a spacer on it. Could that be an issue if there isn't one?
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    This is a Ford Maverick forum.
  6. 71gold
  7. Acornridgeman
    Wisconsin
    Moved to the correct forum
    :Welcome:
  8. 71gold
    was this " loud bang" a missfire type or a metalic sound?
  9. Countryboy0385
    Michigan
    2002 dodge dakota
    A loud bang. Sounded like a misfire out of the right head.
  10. Krazy Comet
    Well leseee, it makes bang and damages sensor??? If that's the case, either something is assembled incorrectly, it's the wrong sensor or maybe is missing spacer as has been suggested... Cam & crank sensors make their pulse by a movement of a closely spaced magnet, pulley etc, if sensor is being damaged there probably isn't enough clearance... Which brings us back to the spacer...
  11. 71gold
    is the sensor damaged when removed?
