2005 crown vic to 1971 maverick
Discussion in 'New Members Forum' started by socket69, Jan 21, 2014.
  1. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Whatever it takes to get a 4R70 OD trans to fit up in there. I personally don't know, but I ASSume it's much larger than a C4. I do know my (relatively small) GM 200R4 OD needed some cutting at the top where the tunnel and firewall meet...
  2. Bryant
    the easiest way to do the wiring/efi is to use an aftermarket fuel injection computer system. i would use the megasquirt 3 on that motor and trans. trying to make the factory stuff work will be a big headache.
  3. socket69
    socket69 Member
    Prattville, Alabama
    1971 maverick
    thanks for the tip
  4. Krazy Comet
    A 4R70W should fit the tunnel of a '71, isn't really any larger than a AOD...
    It's the butt ugly* 4.6 that doesn't have a chance in Hell of fitting unless the shock towers are cut out...
    *Yes that's my opinion but I've owned five 2v 4.6, and I'd never consider one for a older Ford of any model...
  5. socket69
    socket69 Member
    Prattville, Alabama
    1971 maverick
    hey, the crown vic was free got smashed in the rearend, and i just had the idea of putting that updated crown vic engine in the maverick with od tranny, another question will that tranny from 4.6 fit a 5.0?
  6. Krazy Comet
    Nope, the 4.6 from mid '92 used a unique modular only bolt pattern, early 4.6 with AOD did have the small block trans bolt pattern...
    Another thing that would complicate this swap is the trans will have no way to mount a speedo cable, plus '05 was first year for DBW...
  7. socket69
    socket69 Member
    Prattville, Alabama
    1971 maverick
    so in other words just scrap the idea? too much mod than what its worth? well i would like to find an HO 5.0 with a AOD if you know of anyone that has one.
  8. Krazy Comet
    Well that's up to you but unless you have excellent fabricating and wiring skills, you'll soon be in over you head on this one...
    Assuming they don't have a ton of miles, those engine/trans are desirable for replacement in another Crown Vic, Grand Marquis or maybe van/pickup...
  9. socket69
    socket69 Member
    Prattville, Alabama
    1971 maverick
    O i have 1971 f100 short wheel base step i could put it in, Thanks for your info, now its off to find a 5.0 HO with a AOD. If you run across one let me know
  10. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum. :Welcome:If it was me , I would sit down an make a plan on where you are going to put everything. Any thing can be done . It's the time an work you will have to do to complete it . Good Luck.
  11. socket69
    socket69 Member
    Prattville, Alabama
    1971 maverick
    I just would like to have all the updated modern on the old car. Think it would be. I just wanna cruise down the road. I'm gonna give it some thought.
  12. Krazy Comet
    Yeah you'd be far better off with a 5.0, width wise the 4.6 is is 1.5" wider than a 460, but there should not be any problem fitting a 4.6 in most trucks...
    (No not in a early Econoline)
    BTW AFAIK all 4.6 have a rear sump oil pan...
