22 Gallon 70 Mustang Fuel Tank In A 70 Maverick
Discussion in 'General Maverick/Comet' started by bmcdaniel, Aug 16, 2015.
  1. bmcdaniel
    Tanks1a.jpg As most know the 70 Maverick fuel tank was a one year only configuration where the tanks drops in from the trunk and is the trunk's floor. Replacement tanks aren't available and decent used ones are getting harder to find. Thought about a fuel cell but I wanted to keep trunk space because I like to carry a full sized spare tire, tools, etc. So after some research I decided to try and install a 22 gallon 70 Mustang tank to replace the original 16 gallon unit. You can see the difference between the Maverick and Mustang tanks. I came up with 3 or 4 different ways to mount the new tank. What I finally decided on was to make a perimeter frame for the tank out of 1" steel angle. I then used that to figure out where the trunk floor needed to be cut open. I had to move the right wall outward about 6". Frame1.jpg Frame2.jpg Hole1.jpg
  2. bmcdaniel
    A few coats of Rustoleum primer and satin black paint to the bottom surfaces of the tank and frame and we're ready to test fit. You can see the horizontal and vertical holes in front of the tank that will need to be filled in. The frame rests on the the original right & left side and rear lips and is bolted to the sides with eight 1/4-20 grade 8 bolts. The holes in the front are filled in with some 14 gauge steel I had laying around. I found some rust I need to work on over the winter before I finish the trunk and paint it. Paint1.jpg Test Fit.jpg Install1.jpg
    Russell and Paul Masson like this.
  3. mav1970
    Very nice job on the conversion :cheers:
  4. Mavaholic
    Looking good there Barry.
  5. bmcdaniel
  6. Kenn
    Kenn Member
    1995 Ford F150, 2005 Ford F150
    Cool modification. Thanks for the instructions. :cool:
  7. mav1970
    I don't need that conversion for my 70 as it don't need any gas sitting on jack stands :sarcasticclap:
    Paul Masson likes this.
  8. bmcdaniel
    Yeah, but you get really good gas mileage. LOL
  9. mav1970
    Not determined by miles per gallon but how many gallons saved per year :coco:
  10. bmcdaniel
    Forgot to add, the Taiwanese fuel sender o-ring didn't fit right, leaked gas all over the floor. Bought one from CJ Pony Parts that worked. You could see the difference in the O-rings, weren't even close in thickness.
  11. 55crownvic
    55crownvic Member
    colorado springs
    great job, sounds like a winner!!!
    BTW I love your phrase that gets put in all your posts, lol!!
  12. 71gold
    did you ever finish the install...:huh:
  13. satchelmcqueen
    satchelmcqueen Member
    north georgia
    any pics from the back of car ? id like to see if the look changes with the different tank hanging down vs the 70 tank. ty
  14. bmcdaniel
    Finished it in 2015. I'll have to get a pic of the rear, maybe this weekend.
  15. bmcdaniel
    The pic will have to wait awhile, the bumper and lower valance are off the car.
