245 on the fronts
Discussion in 'General Maverick/Comet' started by Cruzin Illusion, Apr 18, 2015.
  1. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Is anyone running a 245 width tire on the front of there maverick/comet?
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Derek (Maverick Man) is.
    Maverick Man likes this.
  3. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    I have them for my car. It's on a 17x8 with 4.5" back spacing. I don't have an engine in mine right now, so it might not be the best to go off of. At full lock they will hit the frame rail on the rear side of the tire. I might end up with a .25"spacer, but im waiting till I get the disc brakes on before I do anything.
  4. blugene
    BFG 245-50-14 on the front of one of mine right now. But they are old and can't get them any more. You can see it in my signature pic below. I am sure it's not close to what you wanted to see, but it's a 245 lol
  5. 71Mavrk
    71Mavrk Member
    Nevada
    235-45-17 on 4" BS. Real close to the lip. Got bad info on the BS. Wish I had gone with 4.5"
    Hope that helps with your set up.
    Micah
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    4-1/2 is gonna rub the inside. I had 235/60-14 on the front back in the early '90s with a 4.25" backspace & 14x7 wheel, and they would lightly rub the inside if I turned the steering wheel all the way to lock.
  7. Cruzin Illusion
    1972 Grabber
    I have 245/40/17 on 17x8 wheels with 4.5" back spacing. I was thinking about changing to a 225/45/17 to hhopefully prevent rubbing. They would still be mounted to the 17x8's.
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I could be wrong, but 17x8 seems pretty wide for a 225. While I think 225 is perfect for the front of Mavericks, you may want a 235/45 if you're gonna keep those wheels. I am hoping to eventually get some 225/45-17s for the front, but on a 17x7" wheel.
    I firmly believe that anything taller than 25-1/2 inches is too tall for the front of a Maverick that doesn't have modified wheel arches like "GrabberGT" has done.
  9. Cruzin Illusion
    1972 Grabber
    For the Potenza RE-11's a 225/45/17 should be mounted on a rim 7" to 8.5" wide. The exact width they recommend is 7.5".
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Okay, so it's not too wide for the tire. 'Might as well give it a try.
  11. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    I have 225 50 16 with an 8' wheel on the front of my car, I can't remember the backspacing...so this may not be of any help to you.
  12. Cruzin Illusion
    1972 Grabber
    Do they rub at all?
  13. gunslinger68
    gunslinger68 Member
    Jackson, WI
    No sir.
  14. Bryant
    im running 255/45x17s. the front valance was trimmed and the fender was rolled and pushed out a bit. they dont rub anywhere with those mods.
  15. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    I have them on my 74 Mav, 245/60/r15 in front and 275/60/r15 in rear
