245 on the fronts
Discussion in 'General Maverick/Comet' started by Cruzin Illusion, Apr 18, 2015.
  1. 71Mavrk
    71Mavrk Member
    Nevada
    Just measured my clearance to the back brace. I have two inches still. I have a Total Control front end with the Shelby drop but I dont think it changes the geometry too much. I think I could have done the 4.5".
    Micah
  2. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    245/40x17s with 4in back spacing and rolled fender lip. Going to try a 265/35x18 in the near future.
  3. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    255/35/18 rubs a little on the frame rail on full lock but probably could use a spacer, it does not damage the tire only polishes my frame rail. No fender mods
  4. injectedmav
    injectedmav Member
    Georgia
    245/50r16 on a 16X7, not 100% sure on the backspacing, but I believe it's 4". rubbed a little on the valance panel but after I adjusted the strut rods while doing an alignment and they clear.
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I'd stay under 25.6" for a front tire diameter. Even at that size, you may encounter rubbing on the pinch weld at the rear of the wheel well or even the bottom of the front edge of the wheel well as Bryant has described. I've hammered my pinch weld flat and still have to watch my alignment to ensure I have no problems. As far as rubbing the inner frame rail, I think that may be a result of your altitude. Lower the car some more and it will likely not be an issue.
    Crazy Larry likes this.
  6. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I run a 235-45-17ona 17x8, 4" BS, the tires will hit the lips at full turn. If you flatten the lip you'll be fine. I can't see you going too much wider than this if its lowered and and not modified. This is on a TCP coilover setup and Bridgestone potenza tires[​IMG]
  7. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Running a 245/45/17 with 4" BS. Rolled front fenders and lowered 1.5" in the front. No Rub
  8. mercgt73
    What width wheel?
  9. Static
    Static Member
    Apache Junction AZ
    7" wheel.
  10. CaptainComet
    When you are really pushing the limits on fitment, be aware that different brands of tires will have differing overall real section widths for the same numeric tire size. Some brands run fat like BFGs, some run skinny like Coopers, and there is everything in between. Most brands will have spec charts posting actual sizes. Most of this difference arises from how comfortable a manufacturer is in meeting the load rating that they have to hit for a given size.
    245 BFGs and 265 Coopers are only about 1/4" different in section width. If going by numbers only it should be 20 mm ... 3/4".
    Static likes this.
