250 rough shut down
Discussion in 'General Maverick/Comet' started by Wutend, Sep 24, 2023.
  1. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    As the title says. My 250 never had problems. But 1 day is started to what is sort of like dieseling but not really. It starts and runs fine but once it's hot. Shutting it down. It acts weird. Just for a second then shuts completely off. I've tried timing but hasn't made any difference. Pretty much everything is stock. Any ideas? I'm thinking maybe the carburetor
  2. Powerband
    Powerband Member
    NY's \H/
    how hot ? - overheating is often cause of running after ign. off
  3. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    Temp gauge reads around 190. I don't even really know how to describe what it's doing really. Not really dieseling but kinda like that. It's just for a second or 2 when I turn the key. It sounds like terrible mechanical stuff breaking. Only once it shot the vacuum caps off the nipples but hasn't since
  4. f4294v
    f4294v Member
    Dallas
    73 comet
    Manual or auto ? Mine has a solenoid that sets idle, that way it doesn't run on. If you have that, maybe you need to adjust. If you have auto, turn key off in gear and see if it helps.
  5. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    It's an
    it's an auto. I'll have to try turning it off in gear when I get a chance. What would cause that just bad carb set up? I've been troubleshooting for about a month now
  6. Krazy Comet
    What gas are you using? If it blew the vac caps, then you no doubt have run on(dieseling). If it's running OK, other than excessive idle speed I doubt you have a carb problem.
  7. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Mine does something similar at times. When I go to shut it off it kinda almost sounds likes its going to keep running for a second then shuts off.
  8. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I normally use 87 octane from Sheetz. I ordered a vacuum gauge hoping the carb is out of wack. It only acts up when it's up to temp. If I go to move the car out of the garage not really warmed up it shuts off completely fine.
  9. f4294v
    f4294v Member
    Dallas
    73 comet
  10. Krazy Comet
    Try 89 & see how it acts.
  11. TeeEl
    TeeEl Senior Member
    Colorado
    Time for a V-8...
    :happy:
    Shorty likes this.
  12. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I thought about a swap but the 6 is so easy to work on. There's so much room for activities
    mojo likes this.
  13. Craig Selvey
    My 250-6 does the same thing. I was told it was the ethanol blended into fuels these days. I shut the car while it is still in gear.
  14. Craig Selvey
  15. TeeEl
    TeeEl Senior Member
    Colorado
    What is the idle speed?...
