250 rough shut down
Discussion in 'General Maverick/Comet' started by Wutend, Sep 24, 2023.
  1. Krazy Comet
    I'd bet it's a simple fix, up the octane.
    Back in day of leaded gas, my 250 Granada would occasionally chunkty chunk at shut down. Never did it running premium.
  2. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    Around 700 or 800 rpm in park. Around 500 or 600 in gear
  3. TeeEl
    TeeEl Senior Member
    Colorado
    Is there a dashpot solenoid on the carb?...
  4. Krazy Comet
    A guesstimate of 100 RPM difference in idle is huge.
  5. William623
    Orlando
    1973 ford maverick grabber
    Try checking your spark plugs. Too much carbon build up on the plugs and cylinders can cause that’s types of symptoms.
  6. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    Theyre brand new plugs. I did stick an endoscope in to look at the cylinders. There's carbon but not bad enough to cause a problem in my opinion
  7. TeeEl
    TeeEl Senior Member
    Colorado
    Advance your ignition timing a few degrees and then back off the idle speed screw to bring the idle back down to 750-800 in Park/Neutral...
  8. Wutend
    Wutend Member
    Ohio
    74 maverick grabber
    I used a vac gauge to tune the carb and put some 93 octane fuel in the bowl. Seems to be fixed for now
