275
Discussion in 'Drag Racing' started by jhehl, Dec 17, 2016.
  1. jhehl
    jhehl Member
    wny
    71 maverick
    im sure this has been answered before but i can find any info. can a 275 drag radial fit in the stock wheel without having to cut anything?
  2. mgabski
    mgabski Member
    1973 Maverick
    I have a 275 60 on my car now. Switching to a 275 50 just because 28s are too tall for my set up. But they cleared with no issues. Alot of street miles and about 15 to 20 passes with the 60s.
  3. mgabski
    mgabski Member
    1973 Maverick
    Here is a picture.
  4. 71gold
    I had 275S 60X15 Pep Boys on 8" rims...no problems. (not all 275s are the same size).
  5. Hotrock
    Munroe Falls, Ohio
    I believe you will need an 8" wheel with a 4 1/2 inch back spacing. I run 255 60 x 15 drag radials on an 8"rim with 4 1/4 inch back spacing. No rubbing.
  6. jhehl
    jhehl Member
    wny
    71 maverick
    thanks for the all the info. i was planning on running 27's. sixkill i really like the way your car looks could you give more info about it as far as suspension, rear end and brakes if you dont mind.
  7. mgabski
    mgabski Member
    1973 Maverick
    Believe it or not factory style everything of what you just asked lol. With me switching to 26s I am gunna be lowering the car about 2 inches all around but right now factory height. 6 cylinder springs up front with no coils cut. It's a 73 so factory disc up front and an 8 inch rear with factory drums
  8. jhehl
    jhehl Member
    wny
    71 maverick
    What kind of 60' are you getting?
  9. mgabski
    mgabski Member
    1973 Maverick
    Nothing specatular. Unfortunately my car looks way faster than it is. Working on cutting down my 1.9. It's not spinning the tires my car just has no low end.
