289 timing chain cover question
Discussion in 'Technical' started by mavmike72, Jan 6, 2009.
  1. mavmike72
    mavmike72 Member
    louisville kentucky
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I didn't figure the rotation of the pump mattered to the cover, but I didn't even go there because I was under the impression that you needed a cover for mechanical pump and dipstick.:huh:
  3. baddad457
    It depends on which reverse rotation pump you choose. Not all will work with that cover.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Read the Tech notes at the bottom of the page
    • M-6059-D351**
    • Aluminum replacement with fuel pump boss.
    • Fits 289/302/351W.
    • For standard rotation pump or M-8501-B50/C50 reverse rotation pump.
    • Has dipstick tube hole.
    Part number M-6059-D351 for standard rotation
    Part number M-8501-B50/C50 for reverse rotation
  5. ratio411
    ratio411 Member
    Pensacola
    All this makes me wonder which rotation cover I used when I replaced the engine in my pickup.:huh:
    It was originally rev rotate. Of course it still is, but I believe I used the Crown Vic's standard rotate cover.:confused:
    Wonder if that will ever bite me in the arse?
    Thinking about the short block laying in my shop... I never took the cover off, so I AM using the 'wrong' cover. No issues yet. Anyone know?
    Oh... "Highjacking in progress!";)
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    Tech notes say either or............the first # is cover and at the bottom it says standard or the # for reverse rotation. Thanks fellas im done...............
  7. baddad457
    The backing plate on the B50/C50 pumps allow it to be used with either style cover. The plate has a round hole instead of a slot where the coolant exits into the timing cover port. Apparently some pumps don't use the backing plate between the pump and cover and those will run into problems when used with the wrong timing cover. The gasket flanges don't match up in this case. Did you check out the late 88-up aluminum Crown Vic pumps Dave?
  8. mean_maverick
    i dont blame you, lol. glad u got it worked out
