289 vs. 302
Discussion in 'Technical' started by chip_gilkey, Feb 19, 2007.
  1. dragracer
    dragracer Member
    Louisiana
    1974 Comet
    yeah right
    LMAo there just aint no friggin way. I have 6500.00in a aluminum headed, 14.5 to 1 balanced ,blueprinted 289 with a 5.56 gear that will turn 10 grand. aint no 2 barrel stock bottom end 289 gonna live past 7 grand but about a minute.
  2. 74merc
    74merc computer nerd
    1974 Comet
    http://www.geocities.com/admmr/MoneyMaker_Racing.html
    I may have some details wrong, again, I said it above. If you have doubts or questions, go to mustangsandmore.com and ask Moneymaker. Its his car and really all I've got to go on is his word.
    For the record, it is possible to make 9000rpms with stock heads, but you won't be making much torque there.
  3. baddad457
    Why build an engine that makes 400 hp at 9000 rpms when you can get the same power at 7500? (or less) THAT is the difference between the two. With a roller 302 you can get the same power at less rpms. And 7500 is not hard to do with a hyd roller. All you need is the right valve springs and ditch the factory lifters. Crane makes replacements that will handle 7500 rpms. They only cost $50 more.
  4. dragracer
    dragracer Member
    Louisiana
    1974 Comet
    I have been racing 289s for 25 years,and I like them. Thats why I build them
  5. baddad457
    Where you located in Louisiana dragracer ?
  6. Maverick6714
    Maverick6714 Member
    Northeast PA
    1970 Ford Maverick, 2004 Dodge Dakota Quad Cab, 1987 Ford Bronco
    352
    Does a 352 even fit well in a Maverick? :bananaman
  7. dragracer
    dragracer Member
    Louisiana
    1974 Comet
    I'm up in Shreveport
  8. dragracer
    dragracer Member
    Louisiana
    1974 Comet
    352?
    A 352 is a FE series Engine. I never tried or even thought about putting one in a Maverick. I really don't think it would even fit between the shock towers without Cutting
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Which 352?;)
  10. ratio411
    ratio411 Member
    Pensacola
    Hooker and Hedman both made FE swap headers for Mavericks until recently.
    I think they stopped making them because no one bothered with the swap.
    I have seen some FE Mavs on eBay, but never seen that swap in person.
    Wasn't popular... therefore the headers didn't sell.
  11. RabidCustoms
    the 289/302 is 24 inches wide,.the 352 (f.e.) is 27".... the 351W is 25" ...and those can be tight.
    might make for a few issues :D
  12. ratio411
    ratio411 Member
    Pensacola
    I don't remember exactly, but I want to say a Cleveland is 27" wide.:huh:
    If you think about it, the Windsor still has room left on the sides because the headers need to go outward towards the towers.
    A Cleveland, and pretty sure the FE, the exhaust exits point down. Meaning the engine can be wider and still fit.
    If the Windsor was 27" wide, or the other engines exhaust exited the same way, then they surely would not fit between the towers.
    My Cleveland was 27" wide (iirc) and used 2" primary headers...
    The FE swap headers were available in several sizes, 1.875" to 2.125".
    Only way that could be is if the exhaust exited Cleveland style.
  13. timers
    timers Member
    richardson tx
    1974 maverick
    We had lot,s of fun in the 70,s with 289,s and even some 260,s. but the 302 is every were now. go with what we can get easy.
  14. RabidCustoms
    sure,...make me dig out the book again :rolleyes:
    351C listed as 25.5" wide
  15. rebeltez
    rebeltez New Member
    louisiana
    1973 maverick
    rebeltez
    my 302 gives me everything I need. I have 330 HP and its super fasst..
