289 vs. 302
Discussion in 'Technical' started by chip_gilkey, Feb 19, 2007.
  1. PaulS
    I know the 302 has a longer stroke and shorter rods....
    I screwed up on the compression height issue - You are correct
    I got the boss 302 mixed up in my mind with the standard 302.
    The Boss 302 has shorter compression height and uses the same length rod as the 289. For some reason I mixed it up in my mind thinking the 302 had a shorter compression height too.
    That was wrong - standard 302 and 289 pistons are interchangeable and the 302 does give up the rod length (all .065") due to its longer stroke.
    5.155 inches for the 289 rod and 5.090 for the 302.
    289 ratio is 5.155/2.87 = 1.796 302 ratio is 5.090/3.0 = 1.697 just under six percent difference. It probably loses some of the power over the 289 because the slight angular difference of the two rods but gains much more with the 4.4% increase in cubic inches and the longer torque arm (4.5%) of the crank.
  2. timers
    timers Member
    richardson tx
    1974 maverick
    ya paul i did the math on that to, good for you to step up. now i have six months to put the xmas tree together can,t do it
  3. PaulS
    Tree as in drag racing? or presents and Santa?
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    OK, I've got a question here......I have a engine I traded for recently, was told it was a 289 from a 67 Fairlane. It has a D5 block casting, which I assume is a 302, so I know it is not original to the Fairlane. The crank though, is a three bolt front pulley, which should be a 289, right? So what is it? A 302 or a 289? :huh:
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    It's definitely not original. One way to tell is to pull the pan and look at the casting numbers on the rods. I don't know what year Ford went to the 4-bolt pulley cranks, but if it's a 289 crank, it's a 289...
  6. baddad457
    Check the crank numbers too. Ford went to the 4 bolt damper in the 70 model year. 3 bolt damper can be either a 289 or a 302.
  7. bmcdaniel
    Yep, check the numbers cast into the crank's front counterweight. 2M =289, 2MA=302.
  8. RegL404
    RegL404 Member
    I believe 1M and 1MA is 289, as 2M and 2MA is 302.
  9. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Pull it apart and check. It could be (gasp!), a 302 block with 289 crank, rods, and pistons. I wonder, if it is, would it be better than a 289 block with 302 crank, rods, and pistons?
  10. bmcdaniel
    Yeah, I think your right. The old memory ain't what it used to be. :rolleyes:
  11. bmcdaniel
    Actually in 1968 when Ford was making the transition from 289s to 302s you didn't know what combination of parts you were gonna get. Blocks could be either and rotating assemblies could be either depending on when the different factories ran out of old parts and started using new.
  12. ford84stepside
    Berry Alabama
    Correction: Block is a D10E, not D5 as previously stated. Rods are also D10E. Only number I found on crank was on rear counterweight, either an 3 or an 8, hard to tell. I'm thinking now, 302, with an early 3 bolt crank, what do ya'll think?
  13. baddad457
    That sounds like 351W numbers.
  14. ford84stepside
    Berry Alabama
    No, it's a 289 or 302. 351 is taller and wider.
  15. bmcdaniel
    Yeah, if the rods have a 71 casting code it's gotta be a 302.
