289 vs. 302
Discussion in 'Technical' started by chip_gilkey, Feb 19, 2007.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Someone swapped in a 302 short or long block (gotta check the heads) and used all the accessories from the original 289.
    That would account for the 3 bolt balancer.
    The 3 and 4 bolt balancers can be used on either crank.
    I'd wager they put in a short block and kept the original balancer so they could use the 3 bolt pulleys.
    Dave
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That sounds reasonable. That's probably why I was told it was a 289. I never checked it untill we pulled the pan to change it to the fox pan for the Mustang. That's just mo better for the drag car!
