295-50-15s
Discussion in 'Wheels and Tires' started by Hottrod1991, Aug 10, 2008.
  1. mavgrab302
    The pulsars are in my summit wish list (y)
  2. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    THE PULSARS are the way to go, yes!!! they look similar to this ones:
  3. ElMachine
    ElMachine Member
    Parts Unknown, Alberta
    1976 Mercury Comet
    I have a set of 295's sitting in my shop I'll try them on the comet tomorrow and see what the deal is. I'll snap some pic's if they fit but the wheels they are on are fairly hideous lol.
  4. ElMachine
    ElMachine Member
    1976 Mercury Comet
    Hey I tried those wheels and tires on, couldn't believe they actually fit fairly good. Wheels only have 3.75" backspacing but are 8.5 inches wide. There is a spot in the front in the wheelwell where it appears it may rub during cornering but a little hammer action would fix. About 1/2" clearance between tire and spring. Just fit in there nice don't stick out in that ugly way they do sometimes. The tread is in the wheelwell where it should be. Check out my gallery for the pics
  5. ElMachine
    ElMachine Member
    1976 Mercury Comet
    Ya they are bolted on the car and it's sitting on the floor, check out my gallery pics to see more
  6. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    1 question: if the bs of the wheel is 4.25 to 5 is bad for the fitting, and if the bs is 4 to 3 is good for the fitting or is it the other way?
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    With a wider rim/tire combo you want more BS as in 4.5bs compared to 3.75..but if you have too much bs it'll hit the leaf springs,easy fix is to shim it out with a wheel spacer.
    if its the other way around only way to bandaid it would be to roll lip or raise rearend
  8. h2o
    h2o Mad Mav Man
    mexico city
    so what you´re saying is that if i put, let´s say, a 15x8 wheel with 4.75 bs it could rub with my leaf springs. and if i put a 15x8 wheel with 3.75 bs it will rub with the wheelwells?
  9. rayzorsharp
    That would be correct...assuming you have a stock rear end housing
  10. elchinelo72
    elchinelo72 Member
    Los Angeles
    71and 72 ford maverick's
    292/50/15 x4
    check the yellow mav at el chinelo72 fotos:thumbs2:
  11. MR T
    MR T Member
    spokane wa
    1970 maverick
    295 50 15
    I Hear a lot of talk about bs my wife say i know a lot about bs or mybe iam full of bs i will have to check with her. at any rate i have had 295 on an old maverick and thay stuck out but is looked good. just run what you brung. thanks
  12. Comet155
    Comet155 Member
    The 275/50-15 drag radials have been a kick in the pants. Good drag gumballs and very nice grip for "enthusiastic" street driving.
    Problem is, they have worn down to looking just about like slicks. I've been nervous that a bubble gum machine might pull me over and write me up.
    Consequently, I began shopping for some wide street rubber. Looked at the Mickey Thompson Radial Sportsman, but didn't like the 235 dollar price tag.
    The 295/50-15's were another option, but I was worried about the extra 1/2" height.
    Despite that, I bit the bullet anyway and picked up some Firestone Firehawk 295/50-15's
    I was waiting for the dreaded rub, but with 1/2 tank of fuel and even a pop over some good speed bumps....no rubbing!
    Granted, the baseball fender lip roll I did for the 275's probably helped.
    Took 3 picks of the new tires and one pic of the old rubber for comparison.
    Oddly enough, the old 275's look as wide if not wider than the 295's
    When the 295's are measured though, they come up about .5" wider. :scratchchin:
    As you can see, even these tires look a bit scrawny for a performance rig, but it's about the max I can mount with the stock wheel wells and springs.
    For my taste, these are about the minimum width for that brutal look. Frankly, I would like some 315's back there.
    Now I just need to pick up a second set of wheels to put the softies on for racing.
  13. Comet155
    Comet155 Member
    I know what you're thinking...come on, no rubbing anywhere?
    Ok, Ok,...I noticed the passenger side tire was scraping on something.
    Turns out it was hitting the traction bar front flange and u-bolt. Grinding down the flange and trimming some of the bolt helped, but also had to move the entire bar inboard.
    The only other thing I found was odd.......I noticed some over-steer going on.
    I played with the tire pressures and have it minimized, but still those sweeping interchange clover leafs require some heightened concentration!
      File size:
      24.9 KB
      98
      File size:
      28.7 KB
      115
    Allen Small likes this.
  14. Felipe
    Felipe Member
    Brazil
    Ford Maverick 2.3 OHC
    If you roll fender lips, 275 tires on 8" wheels fits just fine.
    295 tires on 8" wheels probably fits, but is not recommended. too much tire fot thin wheels.
    I got 295 tires on 10" steel wheels, but to fit properly and avoid rubbing yu got to rebuild the fender border like I did in my Maverick(second pic)
    [​IMG][​IMG]
  15. Comet155
    Comet155 Member
    7th month update:
    They've been a good rag so far for street driving.
    Wearing good, traction decent, and manners are acceptable.
    Virtually no rubbing, except for the occasional enthusiastically approached speed bump with more than 1/2 tank of fuel.
    Happy with 'em so far.
      File size:
      33.5 KB
      121
