3.3 or 289?
Discussion in 'General Maverick/Comet' started by tzayoh, Jan 16, 2013.
  1. tzayoh
    tzayoh Member
    71 maverick
    oh ok, thats what i thought, i should be able to just buy the mounts and bolt the 289 right in right?
  2. MSmithPDX
    MSmithPDX Member
    Portland, OR
  3. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    at the same time when using a 289 or any older motor you should have the valve seats changed over for our fuel i have a 68 302 in my car now ran it for about 3 years and started getting a pretty good skip pulled the heads and the seats are shot
  4. Krazy Comet
    Dismal Swamp
  5. tzayoh
    tzayoh Member
    71 maverick
    if its only nickle and stroke that set it apart then thats not THAT different
  6. Dave B
    It's not, and you'd be way better off with a newer 302 roller motor.
  7. Krazy Comet
    Dismal Swamp
    The bore is same, main difference is rod length and .130 longer stroke of the 302 vs 289...
    Thanks again...
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. he'll want to do at least the exhaust seats to keep them from pounding out and losing massive flow across the newly recessed and extra wide .150+ thou seats at that point.
    And if he runs the prerequisite higher spring pressures on a performance cam?.. it gets even worse with quicker onset of valve recession.
    PS. some times it's like watching a tennis match between 2 comedians with PHd's around here. :clap:
  9. tzayoh
    tzayoh Member
    71 maverick
    do you have to grind the ford ones out?
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    are you saying your existing heads already have hardened exhaust seats?
    not possible to be stock on early motors.. unless someone already rebuilt the head prior and added them. which would save you about $100 or more.
  11. tzayoh
    tzayoh Member
    71 maverick
    no, i dont have the v8 yet, i still have the l6. but when i get it its going to be of a 66, so i want to know if i have to gring the old seats out or not.
    also, i read on another site that the v8 cross member is optional, is that true?
  12. tzayoh
    tzayoh Member
    71 maverick
    also, will 302 mounts work on a 289 if theyre so simular?
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    yes you'll need hardened seats on at LEAST the exhausts since they didn't make it into these/most motors until late 70's and 80's. Unless you run the motor lean for too long a time(causes extra heat).. the intakes are generally cooled well enough by the fuel to not worry about it. That is of course unless you want the motor to last well beyond 200k miles or something.. then by all means.. do them all.
    Not sure about "optional".. but I believe they didn't make it into the V8 cars until a couple years after these cars were produced. I would run one for sure with all the flex in the front ends of these cars. Sure won't hurt.
    AFAIK.. all motor mounts will be the same as the blocks mounting bosses are cast identical to each other and you need only to get the correct one for the chassis it's going into.
  14. Dave B
    Not to mention using a zinc additive in the oil to protect the flat tappet cam shaft, every time you change the oil.
  15. tzayoh
    tzayoh Member
    71 maverick
    damn, im kinda thinking this is gonna be a little more expensive than i can manage if i do it the way i want to. can i just change the AOD bell housing to fit my l6?
