3.55 or 3.80 gears
Discussion in 'General Maverick/Comet' started by BigDog41364, Feb 19, 2014.
  1. mojo
    Without OD, I wud not go w/ anything over 3.55 in a car I plan on using mainly on the street.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You say that now but once you get a taste of it..........:chirp:
  3. stex97
    stex97 Member
    Seattle
    1977 Maverick
    The RPM is also going to depend on your tire size, like others have mentioned.
    My tires are 24" and with the C4 and 3:55 gears I do 3000rpm @ 60. Easy to pass people on the highway at that rate. Just need to make sure you have some good cooling installed. A stock radiator won't cut it.
  4. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    You must have an Obama motor to get 20 mpg with your mentioned set up. I know Texas is BIG and Missouri says show me Va says I don't believe that stuff
    Please reply acceptable explanation. I T T S I F F
  5. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I plan on runnin 345/30R18 (26" tire) in rear with T5/3:55 gears. What would you guestimate I would RPM at @ 70mph?
  6. stex97
    stex97 Member
    Seattle
    1977 Maverick
    Checking my spreadsheets of my fantasy builds that has rpm guesses -
    Unsure of what model T5 you have, a model with either the .68 or .78 final gear, I see that you would be at either:
    2200rpm with .68 final
    or 2500rpm with .78 final
    Checking these numbers at http://www.ringpinion.com/Calculators/Calc_RPM.aspx shows that to be about right.
    Either way, looks like you're sitting cozy for cruisin speed! :thumbs2:
  7. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    :chirp::party3::drive::character0182:
    Hehe
  8. 71gold
    5 speed is basically an OD trans...:bouncy:
  9. scooper77515
    Not sure what that means...:huh:
    I can make it pull 20 mpg if I drive it like a granny. I drove full tank from our house to a car show and back, only passing one or two cars along the way. About 3/4 of the drive was highway, and then some mild city driving.
    Got back home, topped off the tank, and calculated...20 mpg.
    Now if I get on it, and open all four barrels, I can get closer to 1 mpg. I can actually see the needle dropping when I am at the drag strip.
  10. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    When I drove the maveric to Tennessee last summer, I ran it about 75 mph on the highway a got around 17-18 mpg
  11. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Looks like I'm going with 3.55:1 anybody running Richman gears? Curious if the any good
  12. mav1970
    I don't think you could ever go wrorg with Richmond :)
    On other's advice, I bought 3.89's for my 9 inch, due to the cam shaft range in the Cleveland, and they are made by Richmond - granted it hasn't been driven yet :hmmm:
  13. scooper77515
    Mine are richmond. No problems. Buy the installation kit with it and all parts will be included.
  14. scooper77515
    That is not driving like a grandmother. I keep it at 60-65 to get the 20 mpg. 75 for me would likely be similar to what you are getting.
    I think the reason for the decent mpg is that the car weighs next-to-nothing, and 350 hp is barely working to keep it going at speed.
  15. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Does anyone know the number of teeth on the pinion spline? most of what i see on line is 25 teeth, is that what the mavericks have?
