3" exhaust
Discussion in 'General Maverick/Comet' started by yellow75, Sep 20, 2009.
  1. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    My car has 3 chamber Flowmasters ,no H or X pipe and is dumped in front of the axle.
    It doesn`t have the usual "Flowmaster sound" and has a rather low Rumble at Idle ,but when I get on it hard it gets LOUD! My burnout video on you tube gives a pretty fair example of the sound even though its not filmed from behind the car.
  2. Craig Selvey
    NOT 3" though.
  3. yellow75
    Tillamook Oregon
    Thanks for the responses gang. I am thinking I will run 3" with x or h pipe and dump it out in front of the rear tires maybe have a pipe made or buy a pipe flattened out to a rectangle were it comes to the side of car.
    Much cheaper and less hassle with issues than going over the rearend
  4. M.A.V.
    Macon,Georgia
    The angles of mine look kinda weird in this pic they ARE even with each other but you get the Idea.
  5. yellow75
    Tillamook Oregon
    Thanks for the pic M.A.V. that sheds some light on my idea---- it wont work I wanted to bring exhaust clear to the outside of car just in front of the tires but there is just not enough room without using up needed ground clearance. I guess mine will end up looking like yours (y)
  6. blugene
    I kinda think that if you put the mufflers anywhere else other than in the cubbies it does affect ground clearance. Then when they are in the cubbies they are too far back to go to the sides.
  7. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    Same set up as mine....I also have a H-pipe. I am running Flowmaster Super 40's all in 3 inch.
  8. bmcdaniel
    That's when you use these...
