3 leafs or 4 leaf springs?
Discussion in 'General Maverick/Comet' started by coutangman, Jan 15, 2015.
  1. rthomas771
    Like I said...you can't go by on how many leafs are in a spring to know the spring rate. A 76 3 leaf spring has 779 lb. load rate and a 70 4-leaf has 535 lb. The 3-leaf is 244 lb. more than the 4 leaf.
    70 2-door 3-leaf - 535 lb.
    70 2-door H/D 4-leaf - 535 lb.
    71 2-door 3-leaf - 660 lb.
    71 2-door H/D 4-leaf - 708 lb.
    71 4-door 3-leaf -579 lb.
    71 4-door H/D 3-leaf - 595 lb.
    72 2-door 3-leaf - 660 lb.
    72 2-door H/D 4-leaf - 708 lb.
    72 4-door 3-leaf - 579 lb.
    72 4-door H/D 3-leaf 595 lb.
    73 2-door 3-leaf - 660 lb.
    73 2-door H/D 4-leaf 708 lb.
    73 4-door 3-leaf - 609 lb.
    73 4-door 3-leaf - 595 lb.
    74-77 is not broke down on how many doors or if it's heavy duty or standard. I would bet by throwing a hundred pound bumper on the end will call for a stronger spring.
    74 3 leaf 634 lb.
    74 3 leaf 662 lb.
    74 3 leaf 688 lb.
    74 4 leaf 709 lb.
    74 4 leaf 715 lb.
    74 4 leaf 781 lb.
    75 3 leaf 662 lb.
    75 3 leaf 677 lb.
    75 3 leaf 688 lb.
    75 4 leaf 689 lb.
    75 3 leaf 703 lb.
    75 4 leaf 709 lb.
    75 4 leaf 715 lb.
    75 4 leaf 730 lb.
    75 3 leaf 734 lb.
    75 4 leaf 742 lb.
    75 4 leaf 746 lb.
    75 4 leaf 781 lb.
    75 4 leaf 795 lb.
    75 4 leaf 807 lb.
    76 3 leaf 720 lb.
    76 3 leaf 750 lb.
    76 3 leaf 779 lb.
    76 4 leaf 790 lb.
    76 4 leaf 855 lb.
    77 3 leaf 720 lb.
    77 3 leaf 750 lb.
    77 3 leaf 779 lb.
    77 4 leaf 790 lb.
    77 4 leaf 855 lb.
    Mel Moeller likes this.
  2. Dave B
    Like I said, It was part of the option package, the sales brochure doesnt go on about spring rate, you got what Ford gave you.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I ordered 4 leaf on my Stallion. Rides like every other Maverick I have owned.
  4. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    It sure makes it a lot easier with these calculations for me to order a set now. Thanks Jeff.
  5. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    There must be quite a variance in the spring rate and arch of the 4-leaf setups, as mine sat pretty darn level with 4-leafs and 1/4 coil taken out of the front.
  6. Dave B
    if you find a place that gives you all those choices, let us know.
  7. Craig Selvey
    I also cut the front coils....one coil off.
  8. Mel Moeller
    Twin Falls Idaho
    I am not looking for a place that offers all of these options. All I have to do now is find a place that has a 4 leaf for a 71.
  9. mercgt73
  10. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  11. Mel Moeller
    Twin Falls Idaho
    Thanks guys. General Spring is $109.95 per side and Melvin's is $179.95 for a pair. I have put a a email in to Melvin's asking the rating of their set.
  12. coutangman
    coutangman Member
    Charlotte, NC
    Make sure you check to see how much shipping is in addition to the cost. ESPO quoted me $58 for shipping to Florida.
    Jim
  13. Mercurycruizers
    Venetia, PA
    I have 4 leaf on my 73 Comet 2dr. When I had my springs re-arched, I had them add a 4th leaf. I'm using KYB shocks all around. I feel the 4th leaf will keep it from sagging over the years. Rides great....
  14. mojo
    I have Gen. 4leafs on my car. I had to remove the bottom leaf, @808 lbs rating, they rode like a 1ton truck. I removed the bottom leaf after riding on them abt 3 yrs. Removing the leaf was one of the best suspension changes I have made to date; may be one of the best upgrades I have done to the car PERIOD! I only wish I had done it sooner "much sooner".
    I am not the only one who had to make this change. The car rides a lot better; but, if I had to do it again I wud be more aware of spring ratings. When I purchased the units I did not have the info. I have now and was just getting back in the car hobby. I can't see any need for 808lb rated springs for these cars..
  15. Mel Moeller
    Twin Falls Idaho
    Thanks Everett. I have also been told that I should just add another leaf to my 3 weak springs since it is much cheaper.
