300 I6 vs 302
Discussion in 'Technical' started by mavmandan, Sep 10, 2006.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    is the tranns tunnal that much smaller or is the aode alot bigger than a reg aod
  2. rayzorsharp
    Like stated above, the 300 is a much taller engine. A friend of mine bought a 65 Mustang fastback a few years ago which someone had installed the 300 truck motor in. I was checking it out with him. The engine didn't have a breather on it. It only took a minute to figure out why. I looked at the hood and there was an imprint of the top of the carb on it. No room for a breather. I was amazed that it would even run. :huh:
  3. Rando76
    Rando76 Member
    Claremore, OK
    Cut a hole and let it stand tall and proud. :biglaugh:
  4. mavmandan
    mavmandan Member
    Payson Az.
    1970 Mav, really trashed right now
    the motor is a 92, i was just told in 90 they block size went up. is this true? the headers are hitting on the shock tower. i put hookers on it and still hitting. somebody from this site told me to put one side in firts with headers and crank up the other side and slip them in but no go there.
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    The block size did not change on the 302 windsor, ever. You have a header fitment problem, not an engine fitment one. Get the right headers and your problems will go away.
  6. eddie1975
    Martinsburg, WV
    sold
    :agreed: do a search on here about 302 headers , you should find something out:yup:
    eddie
  7. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    The 300 six will fit but it's not a "user friendly" swap. There were tons of these swaps done in the early 1970's for the Modified Production class of H/MP. Dad ran a 1965 Falcon Sprint with the 300 swap against plenty of these Mavericks. It's not an easy deal but it will fit. I do not recommend doing it for a street car of any kind.
  8. don graham
    what number hooker headers are you using? the 6901's are the ones that fit.
