302 camshaft advice??
Discussion in 'Technical' started by runeking40, May 10, 2010.
  1. justin has a 74
    kentucky
    I thought it was around 260:D
  2. mercgt73
    I agree with most of what you said, but I don't think that early EGR robbed horsepower. On a working system, as it still does today, it only dilutes the incoming charge at cruising speeds and maybe idle, depending on the system. It effectively reduces the engine's displacement. Under WOT, a working EGR system does not allow exhaust to flow into the intake.
    Now, it may be true that older systems failed more often than current systems and were not as efficient (efficient as in performing the best an EGR system can). EGR is not a bad thing at all. :yup:
  3. scooper77515
    260 at the wheels. Engine is closer to 330. Thanks for pointing that out, though.
  4. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    scooper where could i get some good priced e7 heads
  5. maverick75
    That's what i meant to say, they were not that efficient. and that's not even getting into the Timing mods that they did...
    And i Know that a perfectly tuned engine will have less emissions :bouncy:
    Because it uses up most of the fuel, and it doesn't just get dumped into the air.
  6. scooper77515
    Hey, since so many guys are talking about what cam to get, I started a thread where I want to post as many cams as possible with a video and/or sound clip so you can hear the cam in action.
    I actually posted a sound clip of the Edelbrock Performer Plus cam when I had it in my car. Of course, when I bought it, it was called the Summit 3600, but same specs, and I heard that they were both made by the same company.
    E7 heads...check your local mustang forum, and keep an eye out for 5.0s in the junk yard. Probably better luck with the forums, but cheaper if you snag them from a junker. Same with the GT40s. Also ebay...but shipping would kill you if you didn't find them local.
  7. scooper77515
  8. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    the problem is that im not using efi engine and the e7 heads are for efi
  9. maverick75
    they will bolt up just fine, you dont need EFI to run these heads.
  10. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    so do engines with efi have the same kind of heads as engines without
  11. maverick75
    basically yes, they might have some holes for the air injection, but you can plug those right up.
  12. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    Would those e7 heads bolt up to my 1973 truck 302 intake manifold
  13. maverick75
    Yes they will.
  14. scooper77515
    My gt40s came off a fuel injected 97 ford explorer.
    I slapped them onto a 74 302 block, then onto an 88 roller block.
    all the same thing,
    All you need to do is swap the spings to match the cam. If mild roller cam, you should be ok, but if you go flat-tappet and/or large lifts, you will need to swap springs. You are looking at maybe $50 or so for new springs (maybe less, I bought mine "at cost" for $32 and swapped only because my lift is a bit more than stock). Ask the cam manufacturer what springs to buy, they will tell you exactly what you need.
  15. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    ok this is my plan i really want some input of what you guys think
    I have a 1973 inline 6 Ford Maverick and i am doing a v8 swap
    The engine i have is a 1979 302 out of a LTD
    I am going to buy a gasket kit from ford racing to change the gaskets
    i am going to buy a maverick oil pan
    I am going to buy some headman headers
    then i am going to buy the parts like cross members and mounts for the 302 in the maverick
    I am going to use http://www.jegs.com/i/Edelbrock/350/2122/10002/-1?parentProductId=749092
    this camshaft
    I am also going to find some gt-40 to put on
    I only have so much money so i will have to do with a 1973 truck 302 intake manifold and 2 barrel carb
    I was wondering if you guys have advice and what you think
    I am really open to suggestion but remember i am not full of money
