302 column shift linkage stud?
Discussion in 'Transmissions' started by ca180, Jul 12, 2016.
  1. ca180
    ca180 Member
    NC
    73 Maverick
    Hey guys, I'm trying to return my car to column shift. Getting rid of the z-gate...
    Anyways, I've got all the rods, but I don't have the stud that goes into the block. This was a 6 cylinder conversion to a 302, hence the floor shifter. But I'd like to get it back to column.
    Can anyone point me in the direction of the right part? I've seen z-bar and equalizer bar studs, but I wasn't sure if that was for the automatic as well.
    Thanks for any help
  2. Krazy Comet
    Not like a Z bar stud... It's just a 2" or so bare ended stud that screws into block, I believe thread is 7/16"... I'll guess 6cyl & v8 linkage are different... If your block is newer than '80 or so it won't have the boss for stud, Mustang venders sell a bracket that's held in place by a couple bell housing bolts...
  3. ca180
    ca180 Member
    NC
    73 Maverick
    My engine is an early to mid-70's 302. I've found the boss just below the manifold. I'm trying to find the bare stud that screws in there. I have a friend that has all the rest of the linkage, except that. Is there a part number that I can reference or a site that sells that part specifically?
  4. Craig Selvey
    The linkage at the bottom of the column has to be for a V-8. 6 cyl is different
  5. ca180
    ca180 Member
    NC
    73 Maverick
    Yeah, I understand. I just need to know the name for the stud in the block. My friend has all the rest of the linkage for a V8
  6. Krazy Comet
    I suspect other than NOS you'll not find, Mustang were all floor shift so didn't use the automatic version...
    You could make a stud from a 302 head or main bearing cap bolt(assuming it's 7/16)
