302 e 303 cam / dist gear
Discussion in 'Parts Interchange' started by 68gtx, Jan 24, 2016.
  1. 68gtx
    68gtx Member
    7o maverick
    Not sure where to post this , excuse me if this is the wrong spot , put an e303 cam in my 302 and not sure if I can run my dist , it has a performance world 6002 dist / hei conversion , not sure what kinda gear it has , tried a search but it is unclear , some say you can run a stock gear with a Motorsport cam , not sure if it's cast or steel , can anyone shed some light on this
  2. Krazy Comet
    Steel cam requires steel or bronze gear... Seen a iron gear eaten by a stock HO cam and the E will be no different...
    I suspect "stock" refers to the gears that are on the factory TFI distributors...
  3. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    You can`t use cast gears on roller cams.
  4. DragPack428
    DragPack428 Member
    Easton, Pa.
    I tried to install the Ford Motorsports steel gear on the Boss 302 dual point distributor I used in my 71 Comet with a F-303 cam. Ruined the distributor shaft as the interference fit was so tight I couldn't get it on and aligned. Researched a bit and purchased Summit Racing MMA-29418 steel gear priced at $39.97 which was a lot cheaper than the Ford gear and easy to install. You had to heat slightly and then drill for the larger pin supplied. You will have to use a press to get the old gear off first.
    Keith Herman
    71 Comet GT
    94 Crate Engine
    5 Speed
    3.80 Detroit Locker
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Other option is to get a Duraspark dizzy for an 85 Mustang GT. That is what I run with my E303.
  6. 68gtx
    68gtx Member
    7o maverick
    And it has a steel gear?
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Yes.
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I believe only the 5 speed cars had the steel gear.
  9. groberts101
    groberts101 Member
    Minneapolis, MN
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I believe I read that as well.
  11. Krazy Comet
    The carbed 5.0 '85 Stang 5-speeds were first to use a roller cam and last 5.0 to use Duraspark... Automatic used a flat tappet cam with TFI dist, this incl '84 as well... The '83 & '84 5.0 5 speed Stang were carbed and had Duraspark but used a flat tappet cam... All passenger car 5.0 from '86 on were EFI & roller cammed, so had TFI dist... the 5.0 F Series went to EFI in 85.5, but continued to use flat tappet cams into the early '90s... Blocks were roller cam ready...
  12. 68gtx
    68gtx Member
    7o maverick
    Also says hei gears cannot be changed
  13. 68gtx
    68gtx Member
    7o maverick
    I ordered up a dura spark 85 , 5.0 5 speed dist today , thanks everyone
  14. Hotrock
    Munroe Falls, Ohio
    You are aware you need an ignition module and conversion harness, right?
  15. 68gtx
    68gtx Member
    7o maverick
    well yes and no lol. i knew i would prob have to run an msd 6al or something with a duraspark dist, which i didnt want to do ,i wasnt aware that i could use the suraspark setup completely, which is the recommeded way to go? msd is ewaasy but pricey, and bulkey, hard to make it look kinda stockish, how do i go about the duraspark complete way if its possible
