302 e 303 cam / dist gear
Discussion in 'Parts Interchange' started by 68gtx, Jan 24, 2016.
  1. Hotrock
    Munroe Falls, Ohio
    I run a full Duraspark ignition system. I also use the dizzy from a 1985 Mustang GT 5 speed car as rotorr22 and Krazy Comet suggested along with a 45,000V coil.
    The following hokey video should provide you full details on parts and installation.
    I've also attached a wiring diagram.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Aren't some (or most) aftermarket roller cams cast iron??
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    yeah.. they're called SADI cores. The hydro roller market is completely saturated with them. Premium and racier stuff gets into the billet cores. Easy to tell true billet shafts by the smooth turned shaft sections between the lobes.
    Crazy Larry likes this.
  4. 68gtx
    68gtx Member
    7o maverick
    So what is a e303 then ?
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    A billet, ground by Crane.
    Hotrock likes this.
