302 Engine Mounts Help!!!
Discussion in 'Technical' started by Derek 5oComet, Jan 5, 2006.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I have a question-- are all the 302 rubber mounts the same? When I pull the engine out of the T Bird , one is a 81, the other a 84, not sure which one I will use yet, will I be able to use these mounts or will I need the 2316 s?
  2. tomeriker
    tomeriker Member
    Indiana
    1972 maverick project..
    mounts
    Aren't the maverick mounts the exact same as the 69 mustang mounts. If so I would tell them they are for a mustang. auto parts stores always have stang part numbers because there is a good market for them..
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    NO
    Our engine mounts are unique to our cars.
    They will not cross from a Mustang or other.
    The frame stands from some early Fords will transfer, but still have to use our mounts.
    Dave
  4. bmcdaniel
    Or if you're really desparate you can do what I did. 66 Mustang motor mounts bolted directly to the frame horns with a 1" spacer between the mounts and the block. Been that way for 32 years now. :D
  5. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Thanks guys got a set from my local napa today. They had to order them in,only took a day.Special thanks to don for the part # it made it alot easier.You guys are the best Derek Elsie.
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Obviously Barry bought his car recently from an old dude,, he cant be that old!
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    Interesting, I recvd the mounts from Parts America. They have a bolt through the center making them more a solid mount. Scotty P
  8. don graham
    glad to hear that you got them. some times what is so hard to find is so easy if you just have the right word or #.:)
