302 five speed to c4
Discussion in 'Technical' started by mywifeisawesome, Jan 14, 2017.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    HI everyone. I'm looking at a 302 that the guy had mated to a five speed. I want to put it in my Comet mounted to my c4. Is their anything I need different to mate it to my c4?
  2. Acornridgeman
    Wisconsin
    If your C4 is mounted to a 250, it has the bellhousing that will bolt to the 302. If you have a 200 with C4, that is a weaker transmission and wrong bellhousing. The T5 has a different bellhousing too that should stay with that transmission when you pull it.
    302/C4 bellhousings are very common and easy to located.
  3. Krazy Comet
    Need more info, what engine is in car now??? Also what year is replacement??
  4. Acornridgeman
    Wisconsin
    I think from early posts - he has a 250.
    But yes, more info would be nice. :)
  5. yellow75
    Tillamook Oregon
    You will need to take the pilot bearing out of the crankshaft on the 302. Since the 302 has a 5 speed I am guessing that it is a roller motor and if that is the case you will have to change a few items on the motor for it to fit such as oil pan. Do your research first
  6. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    I do have a 250. Sorry about lack of info. Trying to get that. It's originally out of a truck, the guy had it in a mustang with the five speed before this.
  7. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    I'm also looking at a 302 out of an 86 lincoln mated to a aod transmission. Would like to mate that to my c4.
  8. Krazy Comet
    You still need to know year or at least the balance of flywheel he used.. Balance changed from 28oz to 50oz in '82... With wrong flexplate you'll have a giant paint shaker...
    Maverick Dude likes this.
  9. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    The 302 in the 86 lincoln is fuel injected. I'd like carb. What all would I have to change on it to make it fuel injected? Also being that it has an aod trans, what would I have to change to mate it to my c4? Thanks guys.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You would need the correct flex plate, not sure which the 250 uses though. If it's 157 tooth you have to go aftermarket to get the 50 oz piece, if it's 28 oz you can pick up a used one.
  11. rthomas771
    The 250 is 157 tooth and will bolt up to a 302...but it is zero oz. imbalance. So the flywheel/flex plate will need to be changed unle$$ machine work has been done to the 302 to make it zero imbalanced.
  12. RMiller
    Kennewick, WA
    Knew you couldn't use the 250 flex plate, just wasn't sure the tooth count. Looks like it will be an aftermarket part for his application, Summit sells them for a reasonable price, that's where I bought mine from.
  13. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks RMiller, and rthomas. Guy wants like 150 for the 302 that was mated to the five speed and the guy with the 86 lincoln wants 50 dollars for his 302 that is fuel injected, I'd like to make it carb powered though, meaning intake and whatever else. So both will work as long as I get a new or correct flywheel?
  14. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi guys, update. The 302 that was mated to a five speed is a 1980 year engine. Thanks so much for all the help everyone. This forum is beyond helpful with the best and most knowledgeable people around!
  15. rthomas771
    Did the engine come out of a car or truck? I'm not 100% sure, but I know someone will correct me if I'm wrong, I want to say a truck came with a 164 tooth...not 157 like came in the cars. (I could be confused about a 351 truck engine)
