302 five speed to c4
Discussion in 'Technical' started by mywifeisawesome, Jan 14, 2017.
  1. Krazy Comet
    Yes AFAIK trucks used 164T but since it was 5-speed makes no difference, he wants to use the orig automatic...
    I'll guess the block plate for 250 & 302 are same???
  2. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Originally was a truck engine yes.
  3. rthomas771
    Yes block plate/transmission is the same on a 250 and 302. The flywheel is different imbalance on the 6 cyl than it is on the 302. The 164 tooth block plate is different than a 157 tooth block plate because of the starter location is different.
  4. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks for the info guys. Sorry about my posts showing twice, my computer wasn't working properly. With the 86 lincoln motor with the aod trans and fuel injection, what would I have to do to mate it to my c4 and also eliminate the fuel injection and run a carb? Thanks again everyone.
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Things needed to change form EFI to card manifold carb ,distributor, if your running mechanical fuel pump you will need to change timing cover for mechanical fuel pump , oil pan to front sump, block plate and flex plate for the right size and imbalance ...
  6. rthomas771
    Wouldn't you also need a fuel pump eccentric to go with the swap?
  7. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks so much for the info guys!
  8. Craig Selvey
    Make it easy on yourself. I have a running driving 302/C4 car here I am parting out. Drive 5 hours over and get EVERYTHING you need for the swap in the correct configuration.
    Hotrock likes this.
  9. Acornridgeman
    Wisconsin
    Pittsburgh to Albany - that is just a lunch run for some of us chasing parts!
    Go for it! :clap:
    Craig Selvey likes this.
  10. Craig Selvey
    And this is not in a pile on a garage floor. We can take the car out and drive around before we pull a thing.
  11. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    How much would u want Craig? Whats it in?
  12. Acornridgeman
    Wisconsin
    The nice thing about a package deal is you can get all the hard to find V8 specific parts in the deal - belly bar, frame and engine mounts, bell housing, throttle cable, transmission cross member - that stuff isn't always easy to find..........:)
  13. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    I agree Acorn, it is the easiest way to go about it. I've been dreading the linkage when that time would come.
  14. Craig Selvey
    Send me an email.
  15. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi Craig I emailed you.
