302 from junk yard
Discussion in 'Technical' started by JD71, Aug 26, 2007.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    and how do i know what springs and so forth work with the cam?
  2. baddad457
    No, the distance from the rocker to the cover roof is more than you'd think. With the 82-85 aluminum stockers, there's a good 1/2-3/4" distance between the rockers and covers. Bolt down the covers as you'd run them (with gaskets), crank it and let it idle for a few seconds, if you hear noise, kill it, remove the covers and look at the baffle under the filler holes. You'll clearly see where they're hitting if they are. As for springs, here's one choice for cams other than those above .515 lift; Crane #44308-1 (springs and retainers, $115 at Summit Racing)
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    ok thanks i guess i was jus informed about the valve covers
  4. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    I have a 1976 Maverick Stallion, and 85 More Mavericks and Comets in Inventory.
    The older engines up to 71 that used leaded gasoline ran cooler,, the unleaded engine blocks can handle more heat before distorting,, the 1 piece rear main seal and the roller cam in the 86 and newer engines is just icing on the cake,,,
