302 help, backfires on warmup
Discussion in 'Technical' started by Bad1974maverick, Jun 29, 2014.
  1. m in sc
    m in sc Member
    rock hill sc
    .. have you recheked the torque on the intake? might be getting hot, expanding and causing a vacuum leak.
  2. Bad1974maverick
    Bad1974maverick Member
    Columbus Ohio
    1974 Maverick Grabber
    yes but as I said it's doing the same thing with a new intake and new carb. It just about has to be ignition. wondering if the distributor is bad?
  3. m in sc
    m in sc Member
    rock hill sc
    change the module in the distributor and the coil, eliminate it as a possibility then. Or it fixes it.
  4. Craig Selvey
    Timing chain loose?
  5. Bad1974maverick
    Columbus Ohio
    ok I might try that next. It's factory so it might be bad. The coil was swapped from my 60 ranchero 289 and it changed nothing. I Haven't timed it yet Craig, but a close friend at CJ pony parts told me to pull the distributor and look for excessive wear on the teeth, as that could be a sign of it trying to seize.
  6. Bad1974maverick
    Columbus Ohio
    Hey guys we found the problem. A wire had rubbed from the engine harness on the top of the motor til bare and that caused said issue. However the car is still overheating even with a new thermostat on the new intake, I think I'm going to pull the engine and replace it. I have a 90 roller motor out of a Bronco ready to go, can I put my carb setup and distributor on this motor and all the accessories bolt on? If so Im going to do that I did a fresh rebuild on it over the winter and I need a backup car for m new job. Any suggestions?
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    How old is the motor and what kind of fan/rad setup are you running
    old
  8. Bad1974maverick
    Columbus Ohio
    The block is a 68 289 block I put in it several years ago, the heads are the factory 74 302 heads it came with. I did oil pump, new lower end bearings, new timing chain and new timing cover then. The fan is stock and the rad. is about 5 years old. The water pump I'm not sure how old it is I came off the original 74 302 block that was in it. I have a 90 bronco roller motor I thought of putting in it till I got the original 302 rebuilt. Will my A/C power steering and all the accessories bolt up to that motor, I can't remember.
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Do you have a fan shroud and what kind of radiator cap are you using?
  10. Bad1974maverick
    Columbus Ohio
    Other than the block the car is completely factory. No fan shroud and stock radiator cap.
