302 vs 351 vs big block fe? Most cost effective option for2x turbo
Discussion in 'General Maverick/Comet' started by masterjames, Apr 16, 2024.
  1. masterjames
    masterjames Member
    Canada
    1973 Ford Maverick 2 door v8
    Hello everyone,
    Can someone please link me to threads regarding the best value for buck/least work for strength in a flat tappet 302/351/bbf for twin turbos.
    I have a stock 302 currently & do not know whether to invest anything into that build that yet or look into a stronger block to start off to run twin turbos (pro street/car shows).
    Hood space & modifications to frame will not be an issue- i can fabricate/change to accommodate.
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    None of those will be cheap, especially the FE.
    For a Maverick, you might consider some of the 4 cylinder turbo engines available from other makes. If you want to have a really quick car, go electric. Google "white zombie Datsun".
  3. masterjames
    masterjames Member
    Canada
    I have an option to get a running 352(?)fe with tranny for $500. Im heart set on a v8 with twins though. Im torn between dropping cash in the 302 that may not be as boost friendly vs the fe that may be stronger from the get-go
  4. krelboyne
    krelboyne Remember
    Salem, Oregon
    Not sure that an FE will drop into a Maverick. Very heavy engines, too. Trans won't fit in the tunnel either.
    The 352's are pretty pedestrian, they make torque though.
    masterjames likes this.
  5. Krazy Comet
    Original 352 heads suck, would need a better set. Center oiling system is questionable for high RPMs.
    Save around 150 lbs, go with 351.
  6. masterjames
    masterjames Member
    Canada
    Thanks for the info!!
  7. masterjames
    masterjames Member
    Canada
    Thanks all for the info!! 351 it is!!
    dyent likes this.
  8. dyent
    dyent Member
    vancouver bc
  9. masterjames
    masterjames Member
    Canada
    dyent likes this.
