302 with aod to c4?
Discussion in 'Technical' started by mywifeisawesome, Dec 28, 2016.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi everyone. I might be buying a 302 from a 86/87 lincoln. It currently has an aod transmission and I want to stay with a c4, will the engine mount up to my c4 trans or will I need something to make it fit? Thanks everybody.
  2. 71gold
    is it a 302 or a 5.0?
  3. Krazy Comet
    302/5.0 from 1982 use a 50 0z balance crankshaft, earlier are 28 oz... What you'll need is 157T flexplate with the 50 oz balance which was never factory but available at Summit, Jegs etc...
  4. baddad457
    X 2 on this . No factory flexplates for this only aftermarket. You will also need to use the 50 oz balancer from the later motor in this case.
    Krazy Comet likes this.
  5. mywifeisawesome
    Pittsburgh, Pa
    1973 Mercury Comet
    Thanks alot guys. It is a 5.0. I'll keep you posted. Appreciate it.
