302 wont turn over after rebuild.
Discussion in 'Technical' started by Bigj47933, Sep 23, 2012.
  1. darren
    Start over. Plastigage and get some hands on help/experience to assemble that lower end. IT sucks if you make a mistake.
  2. Bigj47933
    Bigj47933 Member
    Indiana
    1974 Ford Maverick Grabber , 2006 Dodge Charger R/T , 1996 Honda Accord EX
    Ok so this morning i re disassembled the whole thing down to the bare block. I got some plastigage from the parts store. What should the plastigage read on the mains and rods? I wish I had someone here that had done this before but I've only lived here for a couple years and dont really know to many people that actually build motors. But I appreciate all the help you guys are giving me.
  3. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    Main bearing clearance 0.0025-0.0030 inch (0.0027)
    Rod bearing clearance 0.0020-0.0030 inch (0.0026)
    these should get you into the ball park
  4. Acornridgeman
    Wisconsin
  5. Bigj47933
    Bigj47933 Member
    Indiana
    I did get the green and thanks for the quick response and the how to. Ill get at it this weekend when I have more time to work on it. Thanks again.
  6. Bigj47933
    Bigj47933 Member
    Indiana
    Ok I checked it and three of the rod bearings smashed the plastigauge so much that i couldnt hardly read it. I called the machine shop and they are going to look at the crank and the rods just to double check everything.
  7. Acornridgeman
    Wisconsin
    :thumbs2: GOOD WORK
    I think you have found your problem. I can't tell you over the years how many mismatched bearings I've found. Never ever believe what is found on the bearing box or what the crank grinders says is grind size. Can for cam degrees - test and check all this stuff when building a motor. :)
  8. olerodder
    olerodder Member
    NorCal
    Just as a point of reference for the next time you tackle this type of project is to check the bearings and clearances after getting them back from the machine shop. Invest in a cheap set of micrometers, check each bearing half, and the rod or main throw, also the rod caps with the rods torqued down (this can easily be done in vice), this will give you the exact dimensions and you can calculate what your clearances are before you assemble the motor.
    I always assemble the crank first.............you should be able to spin it by hand. Next I install the cam and timing chain............you should still be able to spin it by hand, then the rods and pistons. It should turn a little harder but take maybe 25lbft to turn the motor over without the heads. You can never go wrong doing it this way.
    I don't use plastigauge because I don't believe you can get a consistant reading..............and don't like doing it more than once..................IMHO
