302's are tuff little motors
Discussion in 'General Maverick/Comet' started by justin has a 74, Jun 9, 2010.
  1. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    So how will that cam work with the lower compression?
    if I`m getting this right,,, everything gonna need balanced
  2. justin has a 74
    kentucky
    Now im lost.:hmmm: The compression will be fine and the cam will work well. Its basically going to be a roller motor with flat top pistons. The new motor is an 87, honned and ready to go.
    Everything is 50 oz for that motor.
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Gotcha! I thought the dished pistons were going in from 77 engine
  4. Bryant
    just because every part is for a 50 oz motor does not mean its a matched balance. the wieght of the rod piston combo is used when the crank gets balanced. sence your mixing pistons and rods the weight most likely will be different than what that crank was balanced with. you really should take the crank, rods, pistons, balancer and flexplate to a machine shop to be balanced. that is usually under $100.00 and can make for a much nicer motor.
  5. maverick75
    Justin next time put your camera on the "macro" setting when your taking close up pics (y)
    It will look like this(flower)
  6. justin has a 74
    kentucky
    I was using my sisters POS camera lol, it cant do anything right:rofl2:
  7. mean_maverick
    better check PTV clearence.....
  8. PaulS
    That piston was likely broken while you were removing it. I bet you did not use a ridge reamer before you removed the pistons. What amazes me is that all of them didn't break a land upon removal. My thinking is that the ring caught on the ridge on the way out and you hammered it out.
  9. justin has a 74
    kentucky
    The piece that fell off was clean, while the rest of the piston was dirty. It could be possible that it cracked on its way out but i just dont see how it did because i could push the pistons out with my hand lol.
  10. rthomas771
    My cheap Kodak Easy Share doesn't have macro settings...just flash settings and zoom. What I do is have the camera set to take high resolution photos then crop the photo. I took this photo about 4-6 feet away and the image is clear. I never use the zoom.
  11. justin has a 74
    kentucky
    I forgot to add that when i had gotten the motor, that piston that was cracked was making a popping sound when you turned it by hand. ROOKIE!!!!
