302's
Discussion in 'General Maverick/Comet' started by Camtemple, Jun 16, 2005.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Ive plugged mine way to many times so I won;t share this time:biglaugh:
    Yea right...........:D
    87 roller block
    10.4 to 1 comp ratio
    KB hyper pop ups
    roush 200 64 cc 2.02I1.60E
    E303 roller cam
    Harland sharp roller rockers
    best time thus far 12.91 and I think I can get it to consistant 12.6s with a little effort. Driven daily until this winter when it gets a much needed make over.
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Im not sure on my block year, as Old Guy just sold it to me. But I had a 80 model 302... but cracked it
    I do know I have:
    Std Bore 302 w/ Speed Pro Flat Tops
    Ported small chamber heads.
    Weiand Xcellerator Intake
    750 Holley Carb
    Erson Cam (forgot specs)
  3. Rando76
    Rando76 Member
    Claremore, OK
    I have a 302 from a '72 Torino. I just got it back from the machine shop - with a few mods. hehe :D
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    1990 302 (5.0) bored/stroked to 347 c.i.
  5. JonnyRebel
    JonnyRebel Member
    Warren Pennsylvania
    1972 Maverick 4 door, 347 stroker, c4
    Bone stock '72 302 with 39k miles.
  6. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    My specs
    87 roller block and heads ported polished w/ 194-160 valves
    Torker 289 Intake w/ 650 Carter AFB
    TRW forged flat tops
    Lunati Voodoo camshaft
    1969 steel crank
  7. j miller
    Polson, Mt
    original 302 to the car . has been pulled out and rebuilt using the edelbrock performer rpm kit. the rpm heads have been massaged a bit, the block was bored 30 over. 10.5/1 compression. best power estimate (not dyno'd yet) is approx 350-365 h.p.
    not to bad for a 4 dr.
  8. oddball4door
    oddball4door Member
    hixson, TN
    Maverick
    '83 302 with 289 Torker, Holley 600, Comp 268H cam. Got Tri-Y's and a set of E7TE heads to add. All infront of an AOD. Not bad for a daily driver.
  9. bmcdaniel
    347, 600 Holley, Edelbrock Performer intake & cam, GT40P heads, nitrous, headers.
  10. tim keck
    sharps chapel,Tn
    The '70 mav has an '88 roller motor,ported E7 heads,stealth & holley,B303 cam.The '72 comet has an '86(flattop)roller block w/stock E7 heads,B303 cam,8011 wieand & holley.The '70's not running yet and due to stock manifolds,converter & 2.79 gears the comet won't fall out of a tree.
  11. rob's74cometgt
    rob's74cometgt Member
    Chilliwack, B.C., Canada
    74 Comet GT
    Hey, Camtemple, I just noticed you're also from Chilliwack. If you ever need a hand, info or parts let me know.
  12. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Flintstone Power!!!:biglaugh: :biglaugh: My 82 302 is still in the T bird donor car!
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    83' roller.
    Eagle 347 stroker.
    SRP pistons
    AFR205's
    Lunati Cam
    Manley pushrods
    Lunati Roller Rockers.
    Super Victor
    Quick Fuel Technology Carb.
