331 build
Discussion in 'Drag Racing' started by Country Mav, Aug 28, 2016.
  1. goldglow73
    goldglow73 Member
    ohio
    1973 maverick 17,500 original miles 302
    It actually had a mexican block so it was 2 bolt. But the mexican blocks mains are much beefier than its brothers. The engine guy said it was a hard block when they bored it. It had a stud girdle/windage tray, and an eagle stroker kit.
  2. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    OK I have the Mexican block also ..347 kit..dart Jr steel heads ..non roller hydraulic cam..revving it 6200 rpm...ran 11 750 on Sunday. .I am not going to push the block any harder..ran it 7 weekends at the track this year.....there is another maverick and a falcon at track running in the tens..they run the svo 4 bolt main block
  3. goldglow73
    goldglow73 Member
    ohio
    What trans setup are you running, what are cam specs, and what gear are you running. I had no qualms about shifting it around 7000 as far a the bottom end was concerned. With the tunnel ram the build was targeted to 4500-7200 rpm range. It pulled HARD from 2nd to third almost like I hit a nitrous bottle!
  4. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    Oh mine is a C4 Trans. .stall is only 2800..410 gear with 28 inch tall tire..glad to hear your motor is working good
