347 Install
Discussion in 'General Maverick/Comet' started by Cloontang, Dec 1, 2016.
  1. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    On the TKO fit .. You will definitely have to perform some SURGERY on the Tunnel . We installed a TKO in a 74 COMET and we had to enlarge the opening, Add a little metal around the opening as well as re-brace the tunnel afterwards. Great Results though .. glad we made the mod.
    Cometized
    (Chip)
    Cloontang likes this.
  2. Cloontang
    Cloontang Member
    Chandler Arizona
    1974 Comet GT
    TKO is already in the car and has been for a few years. We did have to perform a little surgery to get it in.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Didn't realize you had already installed it . We installed 3/4" One Inch Square Tube bracings around the opening and it helped stiffen everything up . Kinda raises the floor doesn't it ? ha .
    Cometized
    (Chip)
  4. 71gold
    I had cal tracs , locker and non sticky tires. my tires are my weakest link, I'm smoking on them all the time. I've had slicks on it at the track a time or two.
  5. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    The 8 inch is marginal for 400 horsepower, but should hold up for quite a while if you don't abuse it. The 9 inch is bulletproof and is much easier to change ratios if you want to. I have a 9 inch Currie with big Torino drum brakes and it works great.
    Lee "THE MAV" Richart
  6. mav man
    mav man Member
    wi
    70mav
    Alston frame connectors,fit great and look good
