347 stroker = how much hp?
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Sep 22, 2008.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i agree this is interesting
  2. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Ok ,let me get this thread straight ,i have a 68 mexican block and the new 347 rotating assemble , also 2 or 3 victor jr intakes ,carbs ,ignition,roller rockers,roller lifters ect ,ect , my machinest said that what i have now in new parts sitting on the shelf i could build a 500 hp engine.I have enough parts to build three engines in my shop becuase i have 4 cars im going to build all v8. Now my 71 grabber in my signiture is my baby ,this one i will spare no expence ,if the boss 302 block will make a much greater bottom end i will buy this block ,but if i buy the boss block i want to push as many hp and torque out of it as i can on pump gas .If the block ,and a new rotating asseblly,new pistons ,new cam ,new heads ,super victor jr intake new carb ect ,ect will give me 600 + hp and 600 ft lb of torque that is the direction i want to go for next racing season ,ive budgeted 8 grand for a new engine,give 2 grand more if i have to.I will put the other Mexican block 347 engine in Bevs (Grabbergirl719) 71 GRABBER .Ive told the machine shop he can build two engines for me in the next 6 months
  3. 71gold
    with that being said,what...parts and block...are at the shop being assembled?...(carb.,intake, heads, rockers, rods, pistons, etc., etc.
    ...Frank...
  4. eddie1975
    Martinsburg, WV
    sold
    600/600 is asking a ton out of pump gas , espcailly 600ft lbs tq your asking a small block to have big block torque
    i just think thats alot out of a pump gas sbf JMO
  5. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    If the tune-up is right, on pump gas he could safely spray a 150 shot and then the 600 is attainable on 93 octane. Is 93 ocatane the highest available at the pump in Canada??
  6. CometGT1974
    Western NC
    74 Comet GT
    I'm fairly confident that my 347 was making at least 600 on the spray.....the block didn't like it and decided to crack under the pressure. It was 10.5:1 and loved pump gas but when I was spraying it I would step up to a good racing gas to decrease the chances of detination. I was spraying a 250 shot. Car weighed 3150 lbs. , and went a 6.08 in the 1/8th mile.
  7. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Canadas best pump gas chevron premium 94 octane ,this thread is getting stupid ,ill just build my Boss 347 engine and when its done ill post pics and a copy of thr dyno runs ,cheers folks ,oh and ill post the cheap Mexicam block 347 dyno to ,both will be built in the next three months. PS my Boss 347 will be built and dynoed in the next 3 weeks to 1 month.I personally think both will push out large hp and torque ,but the Boss 347 will last longer under heavy hp conditiond due to the thicker cylinder walls ,thicker main caps ,4 bolt mains and 1/2 inch bolts
  8. eddie1975
    Martinsburg, WV
    sold
    we still have 93 around here for the most part couple places have 92 but still
  9. 71gold
    with that being said, what...parts and block...are at the shop being assembled?...(carb.,intake, heads, rockers, rods, pistons, etc., etc.
    ...Frank...
  10. Jimmy2gates
    Jimmy2gates Member
    71 mav
    ok frank .here it is to the best of my memory and paperwork 1968 mexican block ,AFR heads 205cc,58 cc chamber ,2.080 intake -1.600 exhaust Rotating assebly Eagle 3.400 stroke 4340 steel crank 5.4 eagle H beam 4340 steel bushed rods.7/16 cap bolts SRP forged flat top 10.9:1 pistons notched for 58 cc heads J@E plasma moly rings CLEVITE 77 main and rod bearings. Comp Cam lift .672 intake .672 exhaust , duration 260 intake 263 exhaust ,victor jr intake ,holly 750 dp,msd ignition ,coen c4 3200 stall,long tubed header 3 inch exhaust through flowmaster mufflers ford 9 inch 4:11 gears, for Bev Grabbergirl719 s grabber ps. going to the B.C LIONS CFL football game tonight with my girlfriend Bev ,goodnight folks
  11. 71gold
    ok frank .here it is to the best of my memory and paperwork 1968 mexican block ,AFR heads 205cc,58 cc chamber ,2.080 intake -1.600 exhaust Rotating assebly Eagle 3.400 stroke 4340 steel crank 5.4 eagle H beam 4340 steel bushed rods.7/16 cap bolts SRP forged flat top 10.9:1 pistons notched for 58 cc heads J@E plasma moly rings CLEVITE 77 main and rod bearings. Comp Cam lift .672 intake .672 exhaust , duration 260 intake 263 exhaust ,victor jr intake ,holly 750 dp,msd ignition ,coen c4 3200 stall,long tubed header 3 inch exhaust through flowmaster mufflers ford 9 inch 4:11 gears.
    what did they need with the: coen c4 3200 stall,long tubed header 3 inch exhaust through flowmaster mufflers ford 9 inch 4:11 gears.
    ...:huh:...
  12. eddie1975
    Martinsburg, WV
    sold
    well its a better combo than small cam and huge carb
    but that cam now is pretty big and i would say the carb is a much better choice
    are you running a solid or hydrolic roller cam?
  13. eddie1975
    Martinsburg, WV
    sold
    yeah i know what you were saying , this is a interesting thread to say the least(y)
  14. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Hey folks ,at least im good for the view ratings ,last i looked this thread had 1500 . LOL:biglaugh:
  15. 71gold
    ...got any pics. yet? :huh:
