347 Stroker
Discussion in 'Maverick/Comet Projects' started by Jsarnold, Aug 29, 2011.
  1. yellow75
    Tillamook Oregon
    I knew it had it in it, I would be willing to bet you will be in the 12s in the 1/4
    Glad all you hard work payed off for you. You didnt blow the power steering dip stick out again did you :D
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Geez, I'd better check!! :rofl2:
  3. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    When you get both start lights on bunp it in 2 or 3 small bumps you will get a better reaction time, always leave the same way just bump in farther or.less To get your reaction time
  4. yellow75
    Tillamook Oregon
    Takes a seasoned racer to do that without red lighting, especially more than one bump. I use a saying in my head once the first yellow comes on I say ready set go
  5. Jsarnold
    '72 Sprint
    Here's a video of the Maverick vs Trailblazer SS.
  6. mavgrab302
    Nice........
  7. Jsarnold
    '72 Sprint
    Next time out I'll try that while watching the tree when someone else is running. See where that would get me going. Definitely have to do something more aggressive at the start to stay ahead of that wicked Trailblazer SS.
    Guess I didn't know what to expect but I'm really pleased the times are that good with shortie headers, not very aggressive cam and 9:1 compression.
  8. Earl Branham
    Lugoff, SC
    Jim, which shorty headers are you using? I have a set of Heddman 88400's, and they don't fit. Pittman arm hits the tube, too far to dent it in.
  9. Jsarnold
    '72 Sprint
    Hey Earl. Headers are Doug Thorley shorties. They fit fine although I did eliminate the bell crank for the c4 column shifter. No drop bracket necessary for PS.
    My pitman arm hits the exhaust pipe but I'm living with it. U-turns to the left can be a problem. Might put a dent in the exhaust pipe some day.
  10. Earl Branham
    Lugoff, SC
    I think I'll try again later, and see if I can get them on. Need the ground clearance.
  11. Jsarnold
    '72 Sprint
    I went with shorties because I didn't want the ground clearance issues. Assumed the shorties would be the limiting factor in engine breathing but just didn't want the exhaust pipes hitting speed bumps. Except for long trips with the wife, I do most of my driving in the Maverick.
    As it turned out, the 347 breathes well enough to suit me. :thumbs2:
