351 c (score)
Discussion in 'General Maverick/Comet' started by togetic2002, Apr 3, 2008.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    oh didnt know that , thought it was an all around thing cool(y)
  2. eddie1975
    Martinsburg, WV
    sold
    what material was used on the C cranks?
    sorrry just being a post whore....3,000 POST WOOT!!!!:bananaman
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    :confused:
    Looks to me like you still got four to go!
  4. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    i have the c4 from my mave but it needs to be rebuilt should i rebuild it and get a a new bellhousing?
    it's a 2v c.
    if i use the c4 i wond need to mod the driveline?
    p.s. by the way thank you for the info hopfuly it'll all go smoothly :burnout:
  5. ratio411
    ratio411 Member
    Pensacola
    If the bell is for a 250 or 302, you are fine.
    If your C4 was behind a 6 cylinder, then you should either build it to v8 standards, then some... or get a C4 that is ready for a decent v8 already.
    The stock I6 C4s have some lighter duty parts.
    Not a problem, as long as you know about it and rectify it.
    As for mods, the 351 will use any and all 302/c4 tranny parts and mounts.
    Most accessories will work too.
    It's a pretty straight forward swap, but it is not for the faint of heart or Ford-uneducated person.
    Gotta figure out what you can hybrid and what you can't.
    Tight fit and time consuming.
  6. eddie1975
    Martinsburg, WV
    sold
    i dont know what happen , i lost posts some where, now im at 3k and some change:bananaman
  7. togetic2002
    togetic2002 Member
    Reno NV
    does the 351 use the same bellhousing? as the 302 ?
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes, same bolt pattern.
  9. togetic2002
    togetic2002 Member
    Reno NV
    o.k. t.y.(y)
  10. stmanser
    Davenport, Iowa
    like my edit says.. i was mistaking the c for the M..
  11. mav1970
    “No one, not even Bob Glidden got a steel crank for his Pro-stock Cleveland. This is one engine Ford never needed to offer a steel crank!”
    My Cleveland was from a Q Code (cobra jet) Gran Torino that I drove to 100,000 miles and the crank was nodular iron. The engine ran strong right up to the time the quarter panels were falling off of it.:)
    “The engine will go in without shaving the towers, however you'll never catch me doing that again! You gotta have that little extra room to save your sanity.”
    BOY YOU GOT THAT RIGHT!!!:mad:
