351 Cleavland
Discussion in 'Technical' started by JD71, Oct 22, 2007.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    that was some pretty neat stuff, very interesting, i didnt know that from the factory the heads where rough and didnt get as good of flow as they should. so i might get the 4 bbl heads port and polished just a little bit though.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Tip:
    You can polish exhaust ports to a mirror finish if you so choose.
    However, intake ports should always be somewhat rough or textured to keep fuel from separating from the incoming air and liquifying or puddling on the port floor/walls. Bad thing!
    (This applies mainly to carburation! Some modern FI systems don't mix fuel into the air until near the back of the intake valve...)
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    if i port and polished the 4 bbl heads how much of a difference would it make and to what size should i go to?
  4. PaulS
    If you are talking about a 351C then unless you are going to run that engine above 8000 rpm you won't need to do anything to those ports.
  5. baddad457
    Port the exhaust sides, leave the intake sides alone, they're big enough already. The exhaust is the side all Ford pushrod V8's need attention to except for the "FE" family.
  6. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    ok but how much should i take from the exaust? and would it help to polish the intakes
  7. ratio411
    ratio411 Member
    Pensacola
    Don't touch the intakes...
    The exhaust just needs blended. If you use 4v heads, don't touch the exhaust floor. Just blend the roof and sides.
  8. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    well i may not mess with any of it. that article said that factory heads had lots of imperfections. thats the only reason i wanted to port and polish them
  9. maverickdvm
    maverickdvm Member
    Michigan
    Cleveland heads are a different beast. Often they are better left alone unless you have the motor to support them. And then if you decide to port/polish them, do your homework or better yet have someone do them professionally. They are good as a bolt on without a lot of work done to them for most street strip engines.
  10. baddad457
    Ditto, that's all I'd do with them. The thing to do with em back when the Prostock guys were running them was to section the heads and install port plates, effectively raising the exhaust roof. ;)
  11. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    any machine work will be done professionally
