351 cleveland in a 72 maverick 6cyl car
Discussion in 'General Maverick/Comet' started by TrotMaverick, Aug 28, 2017.
  1. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    Howdy all!
    I got my car running again and took her to the local car show last weekend. Currently she has a 200 in it. My step brother has a 351 cleveland he's willing to part with and was wondering if the amount of work needed for the swap would be worth the swap. I was originally wanting to leave this car as is, but the more I think about it - the car is not original (My grandpa was T-Boned on the way home from the hospital several years ago, the car was totaled and rebuilt and the engine was replaced due to the damage...thankfully the car took the majority of the damage). I'd definitely like not only a fun project to learn and explore, but also a car that has some more show under the hood (My hood NEVER opens at car shows...she just looks pretty) and a higher performance.
    What are the pros/cons in your opinions and have any of you ever made the swap/how did it turn out?
    My brother is willing to part with the 351C for the cost of clearing out the shed that's at his mom's house and delivering it to him (maybe 10 mile trip) because his mom is crazy and doesn't want him around due to his marriage.
    All opinions are welcomed and appreciated!
    -Tyler
  2. Krazy Comet
    In some ways the Cleveland fits better than 351 Windsor... Mainly exhaust is angled downward at approx 45* vs 90* for the W...
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Pro's:
    * Cool factor
    * Sound. 4V Cleveland's have a throaty exhaust note right up there with a modular.
    * Good power with few mods.
    ** This assumes you are starting out with an early 4V version of that motor.
    Con's:
    * Heavier than both a 302 or 351W.
    * Tight fit requiring specialty Tubular Automotive headers.
    * Cleveland aftermarket parts are more expensive on the average than Windsor related stuff.
    mojo likes this.
  4. CaptainComet
    You will probably want to cut the shock towers. Even with a 302, you have so much more room if they are cut.
    I did my 351W swap in the mid-1990s. It was the way to gain cubic inches back then. It is a squeeze and there are no really good exhaust options. The Cleveland is even bigger. Now, 302-based strokers are common, and that is the path I would take if doing it today. It will fit well and there are big-tube headers to be had.
    Free engine doesn't mean you won't spend more in the end getting it done.
  5. 71gold
  6. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    Are you sure it it the "c" engine? The "m" engine is often referred to as A Cleveland. They share architecture, but are very different.
    Research building the engine. It seems the "C" blocks are prone to cracking, and expensive to build.
    Maybe the engine is all good and ready to run. Mod the engine bay and stuff it in there. Without the shock towers, just about any engine will fit.
    It will be cool no doubt.
    Krazy Comet likes this.
  7. Krazy Comet
    This is a very good point...
    The 351M looks like a C but block is taller, same block as 400... No fittie a Maverick without major surgery...
    BTW there were no Cleveland's after '74, from '75 on they were M...
    Dan Starnes likes this.
  8. mav1970
    Good luck with your swap - it is a bit of a tight fit in a stock engine compartment but many have done the swap using the Tubular Automotive headers - I did mine the first time that way but now it is changed a lot
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Sometimes those low cost engines end up being very expensive.
