351 in a Mav?
Discussion in 'Technical' started by borculo, Aug 29, 2009.
  1. northerndixie78
    northerndixie78 New Member
    michigan
    71 maverick
    im just as excited as my husband (borculo) with our project. He is going to take care of all the motor etc... parts as i am going to take care of all the restoration on the body of the car. any and all information is a big help to us. thanks
  2. maverickfever
    maverickfever maverickfever
    Winnsboro SC
    26 Mavs and Comets
    A wise old man one time told me"THERE IS NO REPLACEMENT FOR DISPLACEMENT" right before his landyacht w/a 429 wipped us all.
  3. borculo
    borculo Member
    Northern Michigan/Bamberg ,Germany
    1971 Maverick 2 dr
    i do have a great woman :)bowdown:northerndixie78) she lives by "there's no replacement for displacement" summit racing has some headers that say they are for a 351 in a Maverick has anyone tried these? heck they are only 99 bucks so i might try them anyway
    also the wife wants a stick and i want an auto which is better for drag racing? and if i went with the manual which is the easiest swap?
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    it's funny cause as i was reading this thread my wife and i were talking about putting a c4 or t5 in my maverick,only mine said "i dont care,i dont want to look at it let alone get in it"
    use the auto for drag racing,same shift speed and rpm every time.with a stick shift you have to shift at the same rpm and not miss a gear.
    i would take a 347 stroker over a STOCK 351 anyday,with the stroker you have a better quality short block.you can get a complete stroker kit for about 700 or so new and balanced.
    here is a good article about the stroker,it's for a 331 but for all intents and purposes there the same.
  5. borculo
    borculo Member
    1971 Maverick 2 dr
    my wife will prolly drive it more than me lol
  6. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    The bellhousings bolt up the same but flex size will dictate the size. A 351w will probably have a 164 tooth flex which requires a different bell than the 157T 302 flex.
    This little detail caused me a lot of frustration.
  7. baddad457
    All you had to do was use the 302 flexplate. ;) Same imbalance for both.
  8. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Well he will need a different bell or flex. WTF is so hard to understand about that?
  9. baddad457
    :naughty: He won't need either if going from a 302 to a 351. What's so hard to understand about that ?:deadhorse You must be the only one who hasn't figured that out yet. :biglaugh:
  10. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    im done....
  11. baddad457
  12. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Just to end the misinformation here:
  13. northerndixie78
    michigan
    71 maverick
    i do be leave our maverick came stock with a V6. so we are not switching from a 302 to a 351. just havent decided what one to use yet.
  14. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Well if you replace the tranny, try to find one that is pan filled. It will be stronger. Then you will need to use a 164 tooth flex on your engine.
    If the I6 was a 250, it will work with a 157 tooth flex. the reason this is so important is that either bell will bolt right up, but if it isn't the right size, the starter won't fit.
    Good luck.
  15. borculo
    borculo Member
    1971 Maverick 2 dr
    maybe i should just put a mopar v10 in it lol
